diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Lettering on transparent panel - Click HERE for Original Thread
GRollins
Anyone got suggestions as to how to get clean lettering on the back of a glass or plastic panel? I want clear letters on a black background so they can be backlit by LEDs or bulbs, not black letters on a clear panel (which would be the easier route). I see stuff like this everywhere, but don't know how it's done.
Yes, I could call a sign-maker's shop, but it's Friday night and they won't be open again until Monday. Surely someone here will know how it's done and I can scratch my curiosity's itch sooner.
Grey
KISS
Educated guess:
Screen printing.
http://www.reuels.com/reuels/Silk_S...structions.html
GRollins
I have silk screened things in the past. I had considered it for this, but I've got a couple of observations:
--The silk screen pigment, be it ink or whatever, is either thick enough that it retains the crosshatching of the mesh it was forced through...or if it was thinned enough that it would flow under the mesh, it was also thin enough to leak under the edge of the pattern I was trying to print. For a T-shirt, poster, or the front of a drink machine, that's not a big problem. For good, clean lettering, it's disasterous.
--The link assumes that you're printing to fabric, paper, or something similarly porous. There's no mention of anything that would adhere to glass or plastic.
Grey
pinkmouse
Use the clear film you can get for overhead transparencies, run it through your printer, and sandwich it between two layers of perspex.
grimberg
Grey,
Would something like this work for you?
http://www.glass-etching-kits.com/index.htm
GRollins
Al,
Yeah, that's kinda my fallback position. That's the method I use for circuit boards these days, so I already have the transparencies on hand. The problem is that the toner isn't completely black. I end up running two passes each on each of two transparencies--for a total of four layers of toner--and it gets difficult to register all four layers properly.
I'm also not sure what I'd use to glue the transparency 'paper' to the glass/plastic, although I'm sure that there are any number of glues that would do the job. Perhaps something like rubber cement.
The overall registering of the print within the glass/plastic would be a cinch, however. All I'd have to do is print a period in each corner, prick it with a pin, drill matching holes in the glass/plastic, and align the whole mess with a bit of wire driven through the stack.
It's just that I'm hoping for a more elegant solution.
grimberg,
I'm not looking to frost the glass or plastic, just mask out parts. My intention is to have print something along the lines of, say, 14 point or so, probably no larger than 20 point. Not very big. It's going to be really easy to lose the clean, crisp edges on the letters. As far as I know, the etching stuff isn't capable of that level of resolution.
On the other hand, perhaps I'd be able to tempt gullible young things by inviting them to come see my etchings.
Grey
Steve Eddy
What size mesh were you using?
Many moons ago I had a very nice 600 mesh stainless steel screen and never experienced that kind of problem.
Got it from a large silkscreen supplier that also carried inks and screens for industrial purposes rather than just t-shirts and stuff. Expoxy inks, special resist inks for printed circuit boards, etc.
Wish I could remember their name. Did some quickie Googling and wasn't able to find them or anyone equivalent. But I think your key to success will be a good quality, very fine screen and the appropriate inks.
Ah! Here you go. Check these guys out.
CRS International
They've got the inks and very fine screens, though they don't seem to offer pre-made screens.
se
SY
With silkscreening, it's a matter of matching ink and image to screen, but more importantly, getting the screen bias angle correct, getting the tension high enough for a good snapoff, setting off contact, and choosing the right emulsion. There's no reason that you can't use a 325 screen and dry emulsion for any reasonable lettering job.
GRollins
Steve,
They have inks they say will adhere to glass and plastic. Might be an option. I wish they had it in something less than gallons, though. It's not like I'll be doing a thousand of these things.
I don't have a clue what the mesh was. It was a light, nearly transparent fabric, but that's all I can remember. This was thirty years ago or more.
SY,
I confess that I'm in conflict with myself over this. I love the way it looks, but have questions about long term reliability. I seem to recall hearing somewhere that McIntosh uses silkscreening to do their glass faceplates. They look nifty, but bubble after a while--and if McIntosh hasn't gotten it right after all these years, I'd rather do something else. Other manufacturers seem to do plastic (granted, I don't know if they're using the silkscreen process), but have not been around long enough to judge durability.
Someone with experience in plastics may pop up and say this is easy...just print such and such a film and heat-bond it to your Plexiglas. I don't know. How the devil do they do these drink machines with plastic fronts? Mass produced toys? Control panels in cars?
I'm trolling for ideas. Don't need colors, just black background with letters left clear. Preferably cheap. Don't honestly care if it's glass or plastic.
Grey
Steve Eddy
I'm going to try and get hold of my laser guy this weekend and see if he might know of a less messy and less expensive solution for this.
se
KISS
Found this: Screen printing inks designed for glass and plastic.
http://www.inkcups.com/dotNet/pages/2j_inks_chart.aspx
What I didn't find though, was a color laser printer that can print on just about anything flat ike thick wood wood or plastic. I saw it in a magazine recently.
GRollins
So I get off of work last night and I'm driving home. Look down at the dash. Scads of buttons. Black plastic with backlit nomenclature. True, the black is matte instead of gloss, and the lettering is translucent white instead of clear, but given how many places you see this sort of thing, I imagine there are several ways to accomplish the goal. It's just a question of getting an overview of each process and comparing them.
Grey
KISS
I found the funky printer.
http://www.ulsinc.com/versalaser/english/index.html
Steve Eddy
Ok, just got off the phone with my laser guy.
After telling him what you were looking to do, he sent me this photo:
For this he just took a piece of cast acrylic, used some Krylon paint that's made specifically for painting on acrylic, and then lasered a positive image on it. As you can see it also includes halftone imaging so you're not limited to straight black and white.
In this piece, where the acrylic is lasered, it's frosted. He says that extruded acrylic can be lasered leaving it virtually clear ("hardly noticeable" he says). He also says that while he hasn't tried it yet, the same technique should be able to be done on glass with the laser power turned down sufficiently that it only vaporizes the paint and doesn't frost the glass.
You say you want the lettering clear, but unless you're going to use something like an EL panel for backlighting, it seems to me that backlighting would be rather problematic without something to diffuse the light.
With the acrylic or glass frosted, you already have a means for light diffusion without having to use a separate EL panel or milk glass to provide diffusion.
If you paint the panels yourself, this could be done rather inexpensively. He doesn't charge large setup fees and pretty much just charges for machine time.
If you'd like to explore this option, let me know and I can put you in touch with him.
se
Steve Eddy
By the way, here's another project he did that involved a piece of synthetic emerald.
First, he just took some masking tape and covered the front surface of the piece of emearld (which he says is about 3" x 5"). He then lasered the masking tape:
It was then sent to a friend of his who abrasively etched the exposed text through the masking tape:
The face of the emerald was highly poslished (you can see the reflection of his hand and camera in the photo) so the abrasive etching created a matte surface which provided a high degree of contrast.
Again, the piece is only about 3" x 5" and the typeface is only about 10 point. So even with abrasive etching, the lasering is able to achieve very fine resolution.
se
SY
Text by KBK?
In any case, screen printing on plastics is routine and easy. The soda machine stuff is usually done on polycarbonate, dashboard stuff likewise. Also CDs. For small legends (e.g., buttons and keys), pad printing is the method of choice.
I'm not sure about diy inks, but when I was doing this professionally, we had good luck with Nazdar for decorative panels and legends.
Steve Eddy
quote:
Originally posted by SY
Text by KBK?
KBK?
Yeah, for those who are already set up to do it. Otherwise, he's gotta buy the screen, emulsion, ink, screen coater, squeegee, make a base for the screen, produce the artwork film, coat the screen, expose it, rinse it, then ink it up, screen the pieces, then clean up the screen and the squeegee if he expects to use it more than once...
On the other hand, he can just buy a can of Krylon Fusion in his preferred color, spray his pieces, drop 'em in the mail, and get them back all finished a short time later.
If he's going to use acrylic, he could use say plain 12 x 12 sheets, then the lettering can be done and the pieces laser cut in whatever shape he wants all in one operation.
se
SY
No, that's good reason to do something else, but a screen print setup can be useful to have (confession: I don't have one any more...). Otherwise, it's pretty cheap to farm it out- there's lots of independent screen printing places in any town of size. Any of them will have the right screens, emulsions, and inks to do a job on sheet acrylic. Just another option.
GRollins
Hmmm...this is getting annoying.
I've already got a perfectly good HP laser printer. Buying another printer just to do one or two pieces of plastic doesn't sound like a good use of pocket change.
I imagine that the photographic emulsion, ninety-nine step silk screen process would work too, but I'd end up with a lot of stuff and things left over. Again, wasteful. Sounds fiddly as all get out, too...which translates as time consuming and more steps for something to go wrong.
SY,
The buttons I'm describing aren't silkscreened. It's some sort of solid process, where the nomenclature is solid white plastic all the way through the thickness of the surface of the button, perhaps 1/16". I remember whittling a button like this with a pocket knife one time. It's either black all the way through, or white all the way through, depending on where you cut. The best guess I could come up with at the time was some combination of injection molding and extrusion, but I never bothered to research it. Note that I'm not saying that it would be economical to have one or two plates run off by this process, I'm just trying to collect ideas. Who knows what will come up?
Steve,
The laser thing is of potential interest, but it sounds like I'd need a bi-color plastic, black & clear layers--not undoable, granted (hell, guitar pickguards have as many as four or five layers). Your observation about diffusion is correct--my default plan is to use a clear front, laser printed negative image of the words, and a translucent white back plane to handle the diffusion. Actually, to be more particular, I'll use several separate white pieces, one for each word, and paint/Magic Marker them along the edges to eliminate back/side scatter of the light, so that if one word is lit the others stay dark. Translucent white plastic would give a smoother, more even "texture" to the backlighting, although I can see how someone might prefer a more granular texture.
Grey
SY
Co-molding.
Steve Eddy
Steve,
No, you wouldn't need a bi-color plastic. Just a piece of clear plastic. You spray paint the back surface the color you want. The laser then vaporizes the paint where the lettering is to go.
That'd work.
se
GRollins
Yeah, but if I can stencil-paint the thing with black paint, then I'm already done...why take the extra step of lasering it?
Grey
Steve Eddy
Stensil-paint? I'm not following you here. How exactly would that be done?
se
GRollins
Steve,
Once I've got a stencil of some sort sufficient to keep the letters clear of paint, then there's no point in going further...by definition, I'll have clear letters with a black background, which is what I wanted in the first place. Why complicate matters by lasering the whole thing, when I've already arrived at my desired end result?
Grey
pinkmouse
I still think OH transparency film would work. The backlight would be fairly dim compared to sunlight or a UV exposure tube, and the reflectivity of the perspex front would improve contrast even further. why not just try it? What do you lose if it doesn't work - 20 pence for a sheet of film?
Steve Eddy
Oh, so you mean the reverse of a stencil, or a mask.
Hmmm.
How do you figure on creating the mask for the lettering that will give you precise locating and good clean edges once it's painted over and the mask removed?
se
tvi
This should get you a even opaque black from a laser printout, Laser Buddy .
quote:
Just spray your documents with Laser Buddy® and watch those pin holes in the toner areas close up -- those gray areas turn solid black. It makes laser printer documents look like phototypeset copy or PMT prints.
James
Chartal
For the stencil you can go to your local custom vinyl decal (car windows decal) with your files.
GRollins
quote:
se
Steve,
Precisely my point, all along. That's the problem with the whole concept of "painting" (I use the term in the broadest possible sense) anything on the clear plastic.
The term mask works for me. I am perpetually short on sleep and was grasping for terms. Stencil was the closest thing I could come up with.
tvi,
That sounds interesting. I'm about willing to bet that Laser Buddy is nothing more than acetone or some similar solvent; clearly something that can dissolve the toner, which is itself nothing more than a thermoset plastic.
The problem I see is that anything that dissolves toner will also dissolve the plastic transparency base. Paper would shrug off acetone (or any number of other solvents), but the transparency would almost certainly shrivel and haze over.
Anyone know where to find an MSDS for Laser Buddy? I'm curious to see what's in it.
At thirteen bucks for a single spray can, I can see myself going into business selling spray solvents. Always wanted a Porsche.
Chartal,
Good idea for the mask/stencil, but the problem remains: Once you get the lettering down and paint over it, how do you peel it up without disturbing the paint?
Perhaps you could have a black stencil made up, apply it, then peel the letters loose to leave clear areas. I'll ponder on this one.
Al,
Yeah, it's looking more and more as though I'm back to my backup concept. I was hoping for something easy, economical, and quick. If nothing nifty pops up in the next day or two, I'll try to experiment with it this weekend.
(What? You thought I could just fire up the laser and try it on a moment's notice? Silly fellow...you've obviously never had twin boys who needed feeding, bathing, etc. My time is not my own.)
Grey
Steve Eddy
Well, the lasering process I was speaking of involved simply painting one side of the plastic or glass solid black. Then the laser vaporizes the paint where the lettering would be, leaving a very precise, sharp image.
The lasering process would be easy, economical, and quick. Not to mention very high quality.
If you'd like, I'll ask my laser guy if he'd be willing to do a sample for you so you can see it for yourself.
se
tvi
Laser Budy MSDS
Ingredient.................................% by Weight
Isobutyl Acetate..........................40-50
Isobutane/Propane blend.............20-25
sobutyl Alcohol............................1-2
Acetone......................................10-15
Ethylene Glycol Monobutyl Ether...2-4
First heard of the product on a diy PCB forum, they use it to get rid of pinholes in transperacies berfore exposure. They do warn it can cause some fogging of the transperancies though.
James
panomaniac
Having tried a lot of these methods, I'd say the paint and laser for best results.
Not cheap in my corner of the world, tho. I was having my logo laser burned into amp panels at $30 a pop. Ouch!
Fast and easy? Follow Pink Mouse's lead. Print onto film. Place film on plastic. Basta.
There was a procuct similar to Laser Budy on a TV craft show last week. Came in a big felt tip pen. The transfers did not look good. Very broken up. It was used for "effect."
GRollins
Steve,
Either I'm not understanding the process you're describing, or you're not understanding what I'm seeking...perhaps both. Let me see if I can try the transparency route this weekend. If it works, great. If it doesn't then we'll prod this laser thing some more.
One benefit to the transparencies is that I can add/delete functions quickly and cheaply. Obviously, I'll want POWER. Okay, no problem. Later, if I decide that I want, say, a MUTE function, I can run off just the one word and strap it in, without having to go through the aggravation and expense of having a whole new panel done.
tvi,
Thanks, that's just what I wanted. And yes, it does look as though there are components in there that would attack plastics. I'm not saying that they should reformulate their product for transparencies, just that it's inconvenient from my point of view.
On the other hand, you could use that to sidestep the $13 per can price if you're working on paper instead of plastic.
Actually, pinholes aren't my main problem with the transparency strategy--it's getting sufficient toner to make it black enough to stop unwanted light from coming through. No spray can can help with that. I have had some success with running the image through my laser printer twice, but it requires care to get the two images to register decently. It works well at the top of the page; less well the further you go down.
Grey
Steve Eddy
Perhaps so.
Okie doke. Good luck!
se
metalman
Grey,
Have a look at www.Lazertran.com. I think it might fit your bill.
Cheers, Terry
troystg
quote:
Originally posted by tvi
Laser Budy MSDS
James
Off topic I know... Sorry.. and to... Well let me just appologize in advance...
Steve Eddy
quote:
Hey, that's pretty cool. 'Specially the water slide decals.
Thanks, Stuart!
se
Steve Eddy
quote:
Ha! Love it!
Apologize? You should be thanked.
Thanks! :D
se
GRollins
Terry,
I'm in a hurry, will take a look later.
troystg,
Love it!
My wife loved it, too.
Somewhere in the bowels of this site there's a picture of two circuits. One is labelled "Man" and has a single on/off switch. The other is labelled "Woman" and has about thirty-eight controls, dials, and sundry weird, random indicators. I used to have the image on my computer, but suffered a hard drive crash and lost it. Someone here may know where it is.
Grey
troystg
"Somewhere in the bowels of this site there's a picture of two circuits. One is labelled "Man" and has a single on/off switch. The other is labelled "Woman" and has about thirty-eight controls, dials, and sundry weird, random indicators. I used to have the image on my computer, but suffered a hard drive crash and lost it. Someone here may know where it is."
troystg
another..
troystg
last one. I think.. :D
GRollins
Troy,
Excellent! Yes, that's the picture I was talking about.
Grey
Page generated in 0.11241888999939 seconds with 17 queries,
spending 0.00993299 doing MySQL queries and 0.10248590 doing PHP things.
Please support our sponsor.
