diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Building the Sjöström's extreme phon preamp - Click HERE for Original Thread
sinigersky
I am intending to build the extreme phono preamp project of Per-Anders Sjöström:
http://sjostromaudio.com/_unsql/hifi/qsxm2/index.html
I want to have a universal "killer" phono preamp, which I'll use to test different equipment. The QXM2 is preferably used with MM pickups.
I am looking for good input transistors to be able to get the "ultra" performance for MC pickup, too. I will be glad to get ideas and recommendations. Has anyone experience with 2SA1455K/2SC3722K? They look good (found them in the forums here), but the problem is I cannot find a supplier to buy them. Any hints about these transistors?
Another solution for MC I am thinking of is using a "head-amp" from here:
http://users.ece.gatech.edu/mleach/headamp/
...for instance the Common-Base Circuit. Has anybody built it? Will the input perform better than the MC-version of the Sjöström preamp? Would it be a good idea to parallel transistors in this schematics? And use floating super regulator with own transformer instead of the battery...
Best Regards,
Angel Sinigersky
KJ42
quote:
Originally posted by sinigersky
... Has anyone experience with 2SA1455K/2SC3722K? They look good (found them in the forums here), but the problem is I cannot find a supplier to buy them. Any hints about these transistors?
I have no experience with Sjöströms designs (except that I have studied them for inspiration), so I have no comment to his RIAA- phono preamps. Regarding the trannies, I believe LC-Audio in Denmark has been using them in their kits, may be they have a surplus for sale?
Back to LC-audio, they have a MC/RIAA phonopreamp which uses a variation of the common base Leach head-amp. I am using a previous iteration of the LC-audio MC RIAA phono preamp (where the PCBs for the head amp and MM RIAA phono preamp are separated) together with a Ortofon MC 25 FL (low output low impedance MC-pickup. LC-audios twist is that they power the head amp with a set of photodiodes in their forward «mode» (no batteries and «total» isolation from the rest of the PSU). I am very satisfied with the performance, very low noise, high immunity to radiated EMI/RFI noise, and clean sounding. I have had some reliability problems (the lamps powering the photodiodes had a tendency to blow); they were solved some 8 years ago, and it has been working flawlessly since. I believe the Leach head-amp design is more suited for low-impedance MC-pickups (i.e. below with a source impedance below about 30 ohm or so), than for high impedance MC-pickups, though I have never tried any high impedance MC-pickups my self.
By the way, I am currently in the design process of an overly ambitious direct input MC/RIAA phono heavily inspired by the Leach head amp, and a previous LC-Audio design or rather a Lars Claussen design - The Air as published by the Danish magazine High Fidelity. My design has differential input, amplification, RIAA-EQ and output. It is a discrete three-stage no-global feedback approach, whith a two-stage/split RIAA-network. I hope to be «publishing» soon (the progress of the actual design has been published in Norwegian at AV-Forum for those interested), though I have been tinkering with the design concept for over 10 years, so don’t hold your breath ... The electronic design as such is more or less finalised, but I sincerely need a hefty push to get on with designing PCBs.
best regards
KJ
PS sorry for the heavy «marketing» of LC-audio (DK). I have no commercial interest in them, I’m just a happy consumer who has some experience with their products, and I like their approach to DIY-/KIT-design and marketing. Their designs are pretty close to «open source», and their marketing in my experience has been non-intrusive and characterised with full information about their products.
phn
All of the above should be good.
Jean Hiraga has dropped the tubes and uses a DIY current-source (FET I believe) amp these days. Hiraga FET MC Phono.
Hiraga's choice of phono stage today is the 47 Labs Phonocube. So this should be another performer.
Page generated in 0.03399395942688 seconds with 17 queries,
spending 0.01102781 doing MySQL queries and 0.02296615 doing PHP things.
