diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Tuner Hum - Click HERE for Original Thread
captaink
Wonder if any body can explain the odd hum I get with a modified Dynaco FM-3. It always happens when the cage is screwed on in it's proper position. If I undo all the screws and move the cage about a bit it will stop when in certain place's. If the cage is taken off all together again no hum. Just seems very fussy with position of cage? I have tried earthing the cage with no success.
Any thoughts about how to sort out problem as I would prefer the cage screwed on. I have young kids with curious fingers.
gpapag
Hi captaink
Might be the screws when screwed in are touching any part of the circuit?
George
captaink
No they only touch the sides of the case.
Page generated in 0.017282009124756 seconds with 16 queries,
spending 0.00817609 doing MySQL queries and 0.00910592 doing PHP things.
