re-using Sillpads and similar - Click HERE for Original Thread
AndrewT
can a Sil pad be re-used?
What if the adhesive side is still intact stuck to the sink?
What if the adhesive has come off on the transistor?
Is there a temperature above which the Sil pad cannot be re-used? Is the texture on the pad an indication that the pad has never reached it's phase change temperature?
What about all the other makes of non-goo thermal conducting pads?
Page generated in 0.019130945205688 seconds with 16 queries, spending 0.00767303 doing MySQL queries and 0.01145792 doing PHP things.
