diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Converting Dac-in-the-box's DAC chip to I/V output - Click HERE for Original Thread
Aleksunder
Ive just been reading an old article on modding DACs, the writer used an AA Dac-in-the-box as a 'mule'
http://www.1388.com/doctor/jonopinion/14022001/
He discusses using the DITB's AD1865 I(current)-out pins (loaded with a resistor), instead of the V(voltage)-out, so bypassing the AD1865's integrated op-amp.
This apparently liberates some clarity, presumably at the expense of reduced voltage at the actual line-out. (As it happens, reducing my DITB's output would be desirable).
Can someone tell me; Is this simply a matter of finding the PCB tracks to the AD1865's V-out, breaking them, and then linking the (appropriately resistor-loaded) I-out pins to the same track?
Page generated in 0.015624046325684 seconds with 17 queries,
spending 0.00763345 doing MySQL queries and 0.00799060 doing PHP things.
Please support our sponsor.
