diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Tube clock??? - Click HERE for Original Thread
quantran
Hi all
I found this link
http://www.thesoundofthevalve.it/AH...tube_clock.html
There isn't much info but the photos look very interesting. What does the tube do in this CDP clock? Anyone has information about it?
quantran
The tube appears to be a triod
http://oldradio.qrz.ru/tubes/russian/short/6s6b-v.shtml
poynton
I would think it was a Colpitts or other 'standard' oscillator using the triode instead of a FET. I dare say squaring is done by a gate.
Does the Xtal have a coil round it ?? or is it just damping material?
Andy
quantran
It's seem to be damping material only. From the photos, I do not see any connection from outer of the crystal to the PCB other than 2 legs of the crystal itself.
kevinkr
As much as I love tubes (look at my posts elsewhere here) I can't imagine this is anything more than a marketing ruse. There are a lot of compelling reasons to use tubes in the audio path if you are so inclined, but I can't think of a single reason to do this as opposed to say the Kwak clock, LCAudio Lclock XO3 or the TentLabs clock. (Or for that matter a good diy clock if you have the instrumentation and patience to design a low jitter, stable clock. ) Tubes wear out and suffer significant parameter shifts over their useful life.
Of course YMMV..
kevinkr
That tube clock is pretty expensive too.. 300 Euro is a lot of money!
jean-paul
But it sounds better because it has a tube in it !!
:clown:
lucpes
My wild guess is that it's a voltage rectifier.
kevinkr
Looking at it quickly I believe it is actually the active element in the oscillator.
quantran
Could it be a Pierce oscillator?
Is it possible that the phase noise caused by the tube is less than that from a transistor?
Page generated in 0.041913032531738 seconds with 17 queries,
spending 0.01537728 doing MySQL queries and 0.02653575 doing PHP things.
