diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Subwoofer to go w/Horn Speaker - Click HERE for Original Thread
jcmjrt
I'm looking at designing a backloaded horn enclosure for a coaxial driver. As you may know, horns get very large as the desired cutoff bass frequency goes low so I'm thinking that I may want to cutoff the frequency in the 70 - 80 Hz range and put a subwoofer in the system to add in the low frequencies.
I'm concerned about how well I could match a subwoofer to a horn. I know that the subwoofer would need to be pretty fast and accurate to match up. Is the cutoff frequency range for the coaxial reasonable and then have a subwoofer go up to 70 or 80 Hz and reach down into the 20s or 30s? Is the frequency range low enough that I could use one subwoofer or would I need two? - I know that the higher the frequency the more directionalized the sound.
I'm hopping that you can point me in the right direction. What designs/type of designs should I be looking at?
roddyama
Here is an interesting thread on this subject
jcmjrt
I agree that it's an interesting thread but I'm trying to find something that will match a horn main (down to about 80/70 Hz) with a non-horn sub. Most of this thread is about horn subs. I think that horn subs provide the best sound but the size requirements even when one goes with a highly compromised 1/8 wavelength horn sub are really large and I was hoping to find something smaller.
I'm going to make horn mains and am wondering if I can match a non-horn sub to sound reasonable with it? And if so, how low do I need to take the mains so that I can use one sub and not have issues because it's directionalized?
What's the experience of people mating for example Fostex or Lowther backloaded horns with a non-horn subwoofer?
Page generated in 0.019865989685059 seconds with 17 queries,
spending 0.00818419 doing MySQL queries and 0.01168180 doing PHP things.
