| hollowman |
DAC chips like PCM1796 seem to offer internal OS filters (e.g. PCM1796 offers 8×).
Outboard oversampling filter chips also exist, such as DF1706. Sales literature from TI notes "The DF1706 is the ideal companion for Texas Instruments's PCM1704 24-bit audio Digital-to-Analog (D/A) converter." BUT, the PCM1704 supposedly features internal OS, anyway. So, why would one opt for a dedicated OS filter? Is this scenario similar to the receiver vs. amp+pre-amp or receiver vs. integrated-amp "debate"?
One more question:
The CURRENT prices of newer DAC chips, like the aforementioned PCM1796, are a LOT cheaper (5.90 USD) than older ones like PCM1704 (30.74 USD). Features/specs-wise, the newer chips SEEM to be "superior". And even TI, on their PCM1704 product literature page, states "Product is Not Recommended for New Design (NRND) ... Replaced By: PCM1796".
How good are the newest chips compared to the older and respected models, such as PCM1704? |
| jean-paul |
| quote: | Originally posted by hollowman
PCM1704 does not feature internal oversampling AFAIK. The reason for using external OS chips was more practical as integration was harder in the past. Also some manufacturers were better in making DAC chips while others were better in making OS filters. For instance Burr Brown DAC chips were used mostly with NPC OS chips. Nowadays integration of functions and costcutting are more important. Sometimes the OS filter and the technical operation of the DAC part are too related to eachother ( as with delta sigma ) to separate them. Manufacturers of DAC chips also tend to integrate OS filters and many other functions in their chips to be able to offer a more versatile product. A low component count "total" solution makes it easier and thus less expensive for OEMs to design and build new devices.
On paper the newer TI multibit Delta-Sigma DAC chips are better. They're also smaller and cheaper to make. It seems these factors are key features for success in audioland. How good it sounds is of less importance ;) Some do sound very good, some are only mediocre in sound quality. The former Burr Brown company had a strong belief in audiophile quality and this was proven with their R2R DAC chips which have a good reputation because of this. Because the older multibit chips itself and their technique are obsolete/unobtanium they have gained a cult status by now.
| hollowman |
More below...| quote: | Originally posted by jean-paul
The reason for using external OS chips was more practical as integration was harder in the past. Also some manufacturers were better in making DAC chips while others were better in making OS filters. For instance Burr Brown DAC chips were used mostly with NPC OS chips. Nowadays integration of functions and costcutting are more important. Sometimes the OS filter and the technical operation of the DAC part are too related to each other (as with delta sigma ) to separate them. Manufacturers of DAC chips also tend to integrate OS filters and many other functions in their chips to be able to offer a more versatile product. A low component count "total" solution makes it easier and thus less expensive for OEMs to design and build new devices.
Do you (anyone reading this) have any personal preferences -- all things being equal -- with respect to non-OS vs. OS vs. US (upsampling) vs. Bitstream/MASH for standard (Red Book) CD playback?
I seem to find a lot of NOS DIY/kits projects nowadays. But my albeit limited experience with a NOS from diyparadise (Monica2) has been not all that great.
I was surprised to see this favorable mention of the TDA1547 Philips Bitstream DAC because MASH/Bitstream chips have been dissed by so many designers.
You also noted delta-sigma superiority with newer TI DAC chips. Do you (anyone) have a general pref. between delta-sigma vs. parallel? The folks at LessLoss seem to highly favor parallel over sigma-delta; specifically, they use the PCM1704 DAC with DF1706 OS filter. But I'm not sure how much of this is marketing and how much is "reality".
In many ways, I keep coming back to square one as far as the "NOS vs. OS vs. US vs. Bitstream/MASH for Red Book CD playback" debate is concerned: Scratching my head! To resolve this I'll ask the following questions:
- Is there a *general* consensus on this issue (well, as far as the myriad DIY audio forums are concerned)?
- Or do DIYers feel that the DAC itself isn't THAT important. Not that it's a non-issue but, rather, one should, instead, pay equal/greater attention to the analog or I/V stage? |
| martin clark |
To look at the problem sideways, the one major difference between the three approaches you outline is what happens out-of-band.
NOS results in full-scale aliasing in the audioband, and images at harmonic frequencies above the audio band, along with a 3dB droop in response across the audioband (no sinx/x compensation). It results in an easy-on-the-ear sound like a vinyl disc that needs washing. Personally - I've heard it, and really don't like it. The big gain is simplicity to DIY, and somewhat reduced jitter sensitivity.
MASH/bitstream offers great linearity when measured, but to achieve this it produces massive amounts of wideband noise that is 'shaped' or shovelled above the audioband where it is assumed to the least damage. How much noise? Well the total energy contained is the same as the wanted signal... but at HF filtering is theoretically easy with just RC elements. These dacs have by far the greatest sensitivity to jitter, which complicates the choice.
Multibit dacs produce the minimum amount of out-of-band noise, and have moderate jitter sensitivity (which depends on oversampling rate) but are difficult to trim for monotonicity (linearity) and expensive to fabricate - hence the difference in prices, and why the true 16-bit dacs have all but dissappeared. From the manufacturers POV, if your customers are buying parts based on %THD and cost, and you can get great figures for both with a one-bit switch and some clever noiseshaping on a cheap CMOS process, then why struggle to make linear R2R dacs in expensive bipolar processes?
So it's a real trade-off. I do think that the attention paid the whole analogue stage design (incuding PSUs and I/V) can make far more difference overall. The real art IMO is control of that out of band noise - and how the system that follows copes with it. But extracting the last 5% that each approach has to offer is far harder, which means direct comparisons are hard to make. I've heard great and nasty examples of each approach... |
| analog_sa |
| quote: | Originally posted by martin clark
It results in an easy-on-the-ear sound like a vinyl disc that needs washing. Personally - I've heard it, and really don't like it. The big gain is simplicity to DIY |
What a wonderful and accurate description. I have certainly heard better highs from cassette decks. |
| ACTIVA |
Hi Hollowman,
You may refer to this tread on the DAC chips discussion :
http://www.diyaudio.com/forums/show...94&pagenumber=2
The Bi-CMOS / Bipolar R-2R ladder type DACs like the PCM1704, PCM1702, PCM63, AD1862 and TDA1541A are / were less cost sensitive designs and optimum solely on the performance area. Hence their higher cost and also need an external FIR digital filter.
The Sigma Delta /PDM /MASH types are CMOS in general and need noise shaping / over-sampling circuitry in order to work properly, therefore the digital filter is integrated in the chip itself. The Sigma Delta types have improved greatly through the years and come with impressive specs, such as the PCM1792 / PCM1794 and AD1955.
Some people still prefer the R-2R PCM1704 than the PCM1792/1794 types on subjective sound quality. But do remember your SPDIF receiver, PCB layout, I/V converters, LPF, power supplies are as important as the DAC chip itself.
Max |
| hollowman |
| quote: | Originally posted by ACTIVA
Some people still prefer the R-2R PCM1704 than the PCM1792/1794 types on subjective sound quality. But do remember your SPDIF receiver, PCB layout, I/V converters, LPF, power supplies are as important as the DAC chip itself. |
Thx for everyone's input.
I've ordered a couple of the chips noted in this thread. Upon testing them in various DAC "back-ends", I'll report back.
I generally feel that newer components perform better than older ones, regardless of technology. (I stress GENERALLY!). I think my experience is correct because:
- mathematical/topological designs evolve (for the better)
- manufacturing technology/techniques improve
- manufacturers -- even the major ones -- do pay some attention to reviews and online forum discussions
OTOH, newer models MAY be compromised because of:
- "cheaper" (inferior) materials (e.g. (semi)conductor grades) and components usage
- miniaturization ... may lead to signal-quality loss
- manuf's change of direction/focus. Some have hypothesized that TI's incorporation of BB may have led to sound-quality compromises. The popularity of "low"-fidelity formats like MP3 (and lack of sales of high-rez formats such as SACDs, DVD-A's, and Red Book CDs) heavily influence corporate decision-making.
-etc.
Technological evolution is often three steps forward, two steps backward -- and these steps are rarely concurrent. |
| martin clark |
I'd broadly agree with all that. The change to using 'multibit' modulators in bitstream is making for some exceptional specs, with a true 20-21bits of resolution being recovereable in some instances. That's a pretty astonishing achievement!
On miniaturisation I'd suggest that - while this does make it harder for us amateurs - the benefits of much smaller current loops far outweight the inconvenience. For example it offers much more effectiveness in PSU decoupling. Compare some of the new SOIC/SSOP pinouts with the old SAA7220 digital filter, where everything inside shares the one supply - and the supply and ground pins are as far away from each other as possible, on a 24-pin DIL... |
| hollowman |
Unfortunately, I lack the technical background to comprehend (and time-effectively further investigate/Google) some of your points. To that end, can you/anyone further elaborate on:
"the benefits of much smaller current loops far outweigh the inconvenience".
"The change to using 'multibit' modulators in bitstream is making for some exceptional specs, with a true 20-21bits of resolution being recovereable in some instances. That's a pretty astonishing achievement!" Which specific DAC chip(s) are being referred to here?
Thx again. |
| martin clark |
Well decoupling is both a science and a black art, but fortunately there's a really excellent article by Guido Tent which offers some insights for the rest of us.
http://www.tentlabs.com/Products/Co..._decoupling.pdf
As for resolution - I'm not really up to speed on current 'best specs', sorry. But the AKM parts used in the Slim Devices transporter just tested in Stereophile turned in better than 20-bit resolution on test (see latest issue), and I bet there are other supplier's parts in the same ballpark.
Just how good this is? Well if you set the full-level output at 2v, the CD standard, then true 21-bit resolution (ie a noise floor 21bits below fullscale) means the noise voltage is about 0.9uV. That's about the same noise in the audio bandwidth as you'd measure across a 4.7Kohm resistor just sitting on the table! |
| hollowman |
I've ordered a couple of the chips noted in this thread. Upon testing them in various DAC "back-ends", I'll report back. |
I've now got a handful of DAC chips (PCM1796, 1798, 1704) and a DF1706 OS filter to play with. But I have two "problems" now (both stemming from my lack of knowledge/expereince no doubt!) :
-- how (where) to obtain inexpensive ($USD) SSOP prototyping boards
-- determining whether SSOP soldering is worth the trouble (IOW, would I be better off using SOIC chips that are not as well rated/reviewed?)
Any advice from well-seasoned DAC builders is welcome.
P.S. I have searched/read thru myriad posts on SOP soldering issues. I'm still unclear as to whether or not to proceed with the project.
Thx again! |
| ACTIVA |
Hi Hollowman,
Take note the PCM1796 needs to work with a micro-controller for internal register configuration, where the PCM1798 is straight external hardware setting, does not require programming. Both offer identical audio performance according to their respective Specs.
You also need SSOP28 to DIP adapters, try some Goggle search.
Max |
| hollowman |
Take note the PCM1796 needs to work with a micro-controller for internal register configuration, where the PCM1798 is straight external hardware setting, does not require programming. Both offer identical audio performance according to their respective Specs. |
Apologies for my ignorance, but exactly how does one configure a PCM1796's internal register(s) with a micro-controller? Can you (anyone) provide a source for such a micro controller?
| quote: | | You also need SSOP28 to DIP adapters |
futurlec.com seems to be a decent resource for inexpensive adapters. The low cost is a refreshing change of pace since many places selling SSOP adapters are quite pricey. |
| ACTIVA |
Any general purpose 8 / 16 bits micro-controllers with I2C / SPI bus interface are OK, but you need to develop your own codes and sort out the timing issues.
If not, skip the PCM1796 and go straight for the PCM1798, no coding needed. The PCM1798 / PCM1794 are external hardware configurable, much more user friendly for DIYers.
Max |
| hollowman |
Thx for your reply.
Does this mean the PCM1796 is ultimately the better choice -- i.e. since timing can be tweaked (and, hence, jitter minimized)?
Your comments re PCM1798 / PCM1794 being "more user friendly for DIYers" is interesting. Earlier I noted what seems to be a popular trend in the DIY audio community: use of Philips TDA DAC chips. I wonder how much of this is actually due to their innate simplicity/ease-of-use -- DIP, only 8 pins -- rather than purely sound quality? My (albeit limited) experience with TDA chips have not been favorable. |
| ezkcdude |
| Are you going to use the DAC for SACD? If not, then there is no need for the PCM1796. Go with PCM1794(8), which are pin-compatible. If you want to see one way to do it, take a look at my website. It's obviously more difficult to prototype and build with SSOP, but depending on your design, you may have no choice. If you want DIP and SOIC, stick with CS8412->TDA154X (NOS). If you're going to upsample using an ASRC (AD1896 or SRC4192, for example), then you cannot avoid SSOP. I do think one of the reasons the NOS approach is so favored is because it is simply easier to build, and less prone to producing duds, due simply to soldering errors. |
| hollowman |
| quote: | Originally posted by ezkcdude
Thx for your reply.
Yes, I was aware of your design via your web site. And it is one of several designs I'm considering for my next DAC project. I am a bit curious as to why you chose UPsampling rather than OVERsampling? The former was, perhaps, a "fad" a few years back but I've, more recently, read some not-as-glowing remarks as to its efficacy.
You asked whether I will use the DAC for SACD? No. But being the owner of several SACDs/DVD-A's -- and a modded combi Pioneer DV-59 player; yes, I *really* do feel that these high-rez formats are *way* better than Red Book, all else being equal -- I would like to sink my teeth into such a project. If it was do'able. AFAIK, there seem to be a lack of DIY SACD/DVD-A *DAC-only* projects. There are very few (if any?) commercial stand-alone DACs that do either or both. Please correct me if I'm wrong! |
| ezkcdude |
Thx for your reply.
Upsampling goes along with the ASRC, which I have converting 44.1 to 96 before the DAC (PCM1794 or 98). The DAC then does oversampling, which is basically undefeatable (except in mono mode). So, I actually am using upsampling and oversampling. It would help if you read the data sheets. That will explain a lot. |
