| ssanmor |
Hello all.
As promised, and "a bit" later than expected, we are glad to announce that we have at last released the next member of our series of audio grade switching power supplies, SPS30.
Its design is very similar to the very well reputated SPS80, although smaller in output power (400W continuous rated), size (only 139.5x89x40 mm) and weight (<450g). As with SPS80, we offer a standard output voltage of +/-60V but we can set it up from +/-40V to +/-60V on demand at ordering time, with no added cost.
This supply is ideal for monoblocks up to 400W, active speakers, hi-fi systems, powerful subwoofers, etc. and will cover the demands of almost any hi-fi diyer. For professional audio or bigger power we recommend SPS80.
You can see more at...
http://www.coldamp.com/opencms/open...roductos/SPS30/
This is a photo of the supply next to a BP4078 module, just for size comparation.
Best regards,
Sergio |
| phase_accurate |
Hi Sergio
It looks nice but maybe you can update your pricelist as well ?! ;)
Charles |
| ssanmor |
Yes! we are on it.
Calculate 80% of SPS80 for each quantity range. |
| ssanmor |
Thanks, Administrator. I see you have moved this thread to Vendor's Bazaar.
Sorry for that, I should have posted it here from the start. |
| m0tion |
| When will the USB DAC be available? Design details? Estimated cost? |
| ssanmor |
It is already available, we will publish the datasheet shortly, if you need the info just email us and we will send it to you.
The base price for 1 unit is 35 euro.
Best regards,
Sergio |
