| imix500 |
Hello all, up for sale is a pile of amps I've collected the last couple years.
I'm selling to finance a try at a KSA-50 and to please the wife.
All amps come from a rental shop and should be expected to have some wear from use.
I have 6 Crown D150's, 1 Crown D75, a Ramsa WP-9110, and a Urei 6250 Studio amp. I will post pics and descriptions as time allows. I can email more photos if desired. Thanks! |
| imix500 |
| A Crown D75 in good working condition. This amp was tested for output power and THD last April and has not seen use since. Not sure of the date of manufacture from the serial #. Maybe someone could shed some light. $75.00 |
| imix500 |
| A Crown D150. This amp is original and has not been powered up do to that fact. $75.00 |
| imix500 |
| A Crown D150. This amp is also original and has not been powered up due to that fact. This one needs a new power cable, is missing knobs, and has one binding post snapped off. $65.00 |
| imix500 |
| A Crown D150. Following the trend, this amp is all original- all of these crowns are. I have not powered it up. A little rougher than the other silver faced amps I have, missing knobs. $70.00 |
| imix500 |
| A Crown D150 Series II. I have not powered it up. One binding post is broken off, missing original knobs. $75.00 |
| imix500 |
| A Crown D150 Series II. I have not powered it up. Missing knobs and power button (switch still functions) $70.00 |
| imix500 |
| A Crown D150 Series II. I have not powered it up. $80.00 |
| imix500 |
| A Ramsa WP-9110. Excellent build quality. Elna and Cerafine caps, Sanken 2SA1216 (can't read it's compliment), nice thick heatsinks. $100 |
| imix500 |
| A Urei 6250 studio amp. Excellent build quality. Rubicon caps, Sanken 2SA1170/2SC2774, huge transformer, big heatsinks. A rare amp. $250 |
| imix500 |
So, to hopefully spark a few buyers I am testing all the amps one by one. Testing will involve reforming the filter caps and looking at a square wave. Other tests can be performed on request.
First Up is DC150 #4. Filter caps reformed great and both channels pass a clean square wave. |
| imix500 |
Ok, all the Crown amps have been checked. Most of the filter caps reformed well but they should still be replaced soon.
Some of the IOC leds are not working. A quick look showed it is probably a bad connection somewhere, but who knows. At least one is working on each amp.
The only amp that showed any questionable behavior was #3. There is about -1v of offset at idle into a 6ohm load. It amplified a sqaure wave well and up to spec, IOC kicked in at about 66 watts. I did not try to adjust the offest.
I am testing the Ramsa and Urei amp now.
Thanks! |
| imix500 |
Ok, both the Ramsa and Urei amps have been tested.
Caps reformed great in both amps.
The Ramsa did 271W and 279W into 3.9ohms with a +4dBu unbalanced input. The amp had more power to deliver for sure, but +4 is as hard as I can drive it.
The Urei did 378W and 370W into 3.9ohms. This was just before any distortion could be seen on the scope. The clip led on channel one didn't illuminate. However it lit with channel two when it clipped. Weird.
I'll give it another week until fleabay.
Thanks! |
| imix500 |
| One more time before they go. |
| dannyr |
I am looking for the crown pre-amp that goes with this series. It's the crown psl-2. If anybody has one, please let me know. Thanks.
Danny |
| imix500 |
Details and pics to follow-
Mackie FR-M1400i
AB Precedent 400
EV 7600 |
| imix500 |
A very nice, well built amp. Makes the second best sqare wave on the scope of all the amps I have for sale.
All original inside.
Power quoted is just before clipping into ~8.5ohms:
Ch A- 197.87W
3mV offset
Ch B- 206.40W
8mV offset
Bridged- 501.76W
$150 |
| imix500 |
EV 7300A Good condition.
Ch A- 280.004W
Very little offset
Ch B- 294.12W
Very little offset
Bridged- 660W
This one could probably benifit from more capacitance.
$150 |
| imix500 |
This ones kinda of a wreck. All 4 psu caps are bulged and all 4 rail fuses blown. Don't know much background other than the amp was clogged with dust balls and so probably overheated..
I get 65.8-0-65.8, and then 6-0, 0-9, and 100v from the 6 to 9. Probably just not metering it right. Anyway, torriod seems fine. Lots of good parts, and the chassis is in good shape. I'll start at $75 but make me an offer. Thanks! |
| imix500 |
I do have one interested party in the EV, but nothings in stone yet.
All other amps are still available. |
| skittletata |
HI would you ship north of the border?
if so can i get a shipping quote on the ramsa to montreal? postal code H2W 1X9
(quebec, canada)
thanks
scott. |
| imix500 |
Hi Scott,
sure I will.
Looks like about $52 via USPS Priority, and $34 for UPS Ground. |
| skittletata |
ok 2 more questions,
1) did the EV sell and
2) do you think yo ucould put 2 amps in one box or would it be too heavy and require 2 seperate packages?
(im considering either teh ramsa or ev adn a crown d150) |
| imix500 |
The EV is sold pending payment at the moment.
I could probably put both of them in one box, but I would need use a stronger way of packing due to the weight ~50lbs. Looks like about $53 to ship plus packing. Email me if you'd like to discuss. Thanks! |
