diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Digital out on Audigy 2 - Click HERE for Original Thread
maczrool
I have a new Dell computer with Audigy 2 card. For sake of avoiding running wires across the floor, I like to run the computer S/PDIF sgnals over a 2.4 Ghz video link. However, due to the WAY out of spec voltage level of the Audigy 2 card, this is not possible. Using an oscilloscope, I determined the voltage on the digital out is 9 volts P-P! This is too much for the video transmitter, but does work with a direct cable connection.
Anyone else notice this, or is there something wrong with my card? Could I just build a buffer circuit to lower the voltage to something more reasonable?
Stu
maczrool
A 500 ohm resistor seemed to do the trick.
Stu
Page generated in 0.021056890487671 seconds with 16 queries,
spending 0.00941896 doing MySQL queries and 0.01163793 doing PHP things.
Please support our sponsor.
