diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
Isolation Transformer question - Click HERE for Original Thread
Jack Torrance
Ok, I know this is going to seem like a stupid question, but I am going to ask anyway. I bought a medical grade isolation transformer off of ebay because I planned to hook my CD player up to it to keep the line clean -- the transformer came late today and all of the plugs are female. So, stupid me-- how do I use this thing?
janneman
Replace the plugs? No seriously. Why not post a pic so we can advise you. Do you have data on the connections of that thing?
Note that medical isolation transformers basically are spec'ed to give better isolation between primary and secondary. That doesn't mean better audio performance, BUT there probably is a screen between primary and secondary. Grounding that screen at a well-chosen point will help to keep mains-borne noise and interference out of your equipment and THAT definitely gives better audio!
Jan Didden
Jack Torrance
This is not mine, but this is the type of plug mine has, as opposed to a US wall outlet...
paulb
You can buy plugs to suit those outlets.
batee
Radio Shack (I know) sells adapters intended for the switched outlet on PC power supplies. It has the male IDC plug to match your xformer, and has a female wall plug on the other end to accept your cord.
Jack Torrance
Thanks, batee! That was the answer I was looking for. Now let me ask about what exactly do I need to do to ground the screen as janneman mentioned to see an improvement in my audio?
janneman
quote:
Jack,
I was assuming from your post that you had a bare transformer, which you needed to wire up. Now, if this one is a medical isolation transformer pretty sure the inter-winding screens are already wired up correctly. The only way to verify is to dismantle the thing but then you also need to know the various transformer leads and connections.
Jan Didden
Jack Torrance
Very good! Thanks for the suggestions, everyone!
Page generated in 0.025515079498291 seconds with 17 queries,
spending 0.00888896 doing MySQL queries and 0.01662612 doing PHP things.
