diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Xitel's Pro HiFi-Link - Click HERE for Original Thread
cbloss
Has anyone tried or know about Xitel's Pro HiFi-Link? What kind of quality will a system like this put out compaired to the upper end sound cards you guys are used to?
http://www.xitel.com/subset_PHFL.htm
brentw
Good Question and what chips are in the box?
The link has moved to here now:
http://www.xitel.com/product_phfl_02.htm
dsavitsk
The Xitel has a Sonix SN11113F to convert USB to S/PDIF, and a VIA VT1612A audio codec.
Performance of the Xitel is so-so. The analog is bettered by the M-Audio Sonica (which is not so good in its own right). Digital is bettered by my own project based on the PCM2902. The one thing the Xitel has going for it is a coax digital output which is rare on usb devices.
brentw
Hmm... I think the PCM2706/7 has SPDIF out. I recently connected the PCM2706's I2S output to a TDA1543 and find it sounds better then the SPDIF interface.
http://www.diyhifi.org/forums/viewtopic.php?p=6379#6379
I will try the SPDIF out and report back here. But in a day to two, my day job needs some attention.
Oh... where is my manners. I almost forgot. Thank-you for answering my questions.
Page generated in 0.024435043334961 seconds with 17 queries,
spending 0.00733876 doing MySQL queries and 0.01709628 doing PHP things.
