diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
SMPS-PWM design with bipolar supplies - Click HERE for Original Thread
rtarbell
When making an SMPS supply using a PWM controller IC and two NFETs for switching, many of the topologies use a high-side driver to drive the upper FET, and the low-side FET is referenced to ground; this assumes that the ouptut voltage needed is positive.
What solution is there if a negative output voltage is needed for high power designs? Is there such a thing as a PWM controller for negative voltages, while still using NFETs?
DJ Exprice
I'm a newbie to SMPSs, but I'm almost perfectly sure that there is. It wouldn't make sense that there wouldn't be one...:smash:
Tekko
http://schmidt-walter.fbe.fh-darmst...s_e/smps_e.html
This site is unvaluable when it comes to smps theory and calculations.
Page generated in 0.016072988510132 seconds with 17 queries,
spending 0.00646544 doing MySQL queries and 0.00960755 doing PHP things.
