diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
what use for a boost converter ? - Click HERE for Original Thread
Tekko
I built a boost converter yesterday without knowing it @ first, now the question is, what can one of these be used for ?
Heres a schem and some pics of the thing.
http://img207.imageshack.us/img207/...cture009uj7.jpg
Heres a video of it doing 12-24 (guessed) volt out to a little motor.
http://www.youtube.com/watch?v=Ub6SzmrP0Ak
Input is 12v from a battery pack, and a estimate that it doubles the voltage. The inductor is from a energysaver lamp ballast so i dunno inductance.
ACD
Congratulations ;)
You just build a 12 to 24 V DC to DC converter :D
Great for driving 24VDC equipment fron your ordinary car battery ;)
Tekko
The weird thing is i built it without myself knowing it, dident know what the heck it was until i checked that smps site.:bigeyes:
Does that mean i suck on electronics ? Any easy way to find out the inductance of the coil ?
What factors determines the output voltage, caps max volt<age, switching fet, diode ?
ACD
Why do you think you suck at electronics ???
I consider my self very experienced, but I don't no a s*** about smps designs, so I would feel like you if I had build it :D
You ask what determines the output Voltage....
I may not be the right to reply, but I guess that the 555 toggling frequency and the cap sets the max load you can connect :angel:
Tekko
Maybe Eva knows the answer, Tho my switching fet only takes 100V so maybe i shouldent attemt to get the voltage up much more as i dunno what it is unloaded.
I have seen a boost converter doing 100v from a 8.5V source, it wasent too different from mine except diff 555 topology.
sawreyrw
Tekko,
You can find thousands of good references to boost converters on the Web. IC and magnetic vendor information is especially helpful. See for example; www.linear.com.
The circuit you have shown is indeed a boost converter, but it has no voltage regulation, because it is open loop.
A simple way to understand boost converters is to think of energy balance. Assuming discontinuous operation, the inductor energy is
1/2 L I^2. This energy goes into the load and the output cap. The cap will charge up until this is satisfied. This could lead to excessive cap voltage without the necessary feedback.
Rick
luka
In your case output voltage depends on frequency, higher freq., higher output voltage.But if there is current demand, voltage will fall down, as you would have current limiting. I think...:cannotbe:
Tekko
I had closed loop earlier but i removed that as i was so high in voltage that it threatened to blow up the 555.
Tekko
Now i have done some measurements and calculations and found out that total effecienty is around 90-95%, not bad for something tossed together over an mxas eve.:D
Unloaded output voltage is 65 volts, when loaded with 400mA voltage is around 20-22V, at input this corresponds to 6.4 volts on the battery back that reads 11.95V unloaded, and 1.5-1.8 Amps. So output 8 watts and input 8.25 watts, the measurements and math says 96% eff, not bad!!
luka
haha thats really good. probably it could be better if you had higher input voltage, something like 12v.
Tekko
Now i have ran it on a puter ps on 12v and with that i can reach 60v unloaded and around 55v with two tape recorder motors in parallel.
luka
What kind of consumption is then?
Tekko
A boost converter that doubles voltage halves the current, if voltage is 3 time higher the current is 3 times lower and so on.
Page generated in 0.030422925949097 seconds with 17 queries,
spending 0.00686216 doing MySQL queries and 0.02356076 doing PHP things.
Please support our sponsor.
