diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
T-amp PSU cap wiring - Click HERE for Original Thread
xyrion
Hello,
I was wondering if I could add extra PSU capacitance for the little T-amp like shown on the attached scheme? Would this approach be better than the usual cap over + and - in any way?
PSz.
The t-amp uses only a positive voltage and ground. You have drawn a positive-ground-negative supply. This would only apply to the larger tripath chips. A standard (or modded) sonic impact (or similar) would not benefit from this proposed psu.
best regards,
psz.
panomaniac
Adding big caps will help the T-Amp. You get a more stable power supply rail
As noted in the post above, you have shown a split rail PSU. The small T-Amps use a single rail. Otherwise, this will help. So will getting a large, good cap near the chip.
xyrion
Thanks for clearing that out for me.
Page generated in 0.019180059432983 seconds with 17 queries,
spending 0.00939727 doing MySQL queries and 0.00978279 doing PHP things.
