diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
What waveform to use for testing? - Click HERE for Original Thread
__BriKs__
Hello,
To introduce me I'm a beginner and I try to design my own class D amp. My question is about trig generator for no self oscillating design. I saw on Internet that the less the trig amplitude is the less distorstion you have. However with little amplitude you can have a lot of noise.
So I use a specialized ic to have my trig waveform (yes I'm a beginner, I cheat, I use specialized ic dont hit me :) ). A xr2026 so I think it is able to generate audio signal level triangle without too many disto ( 2V p-p ). It is a good idea to have a 2v p-p trig waveform or it is best to reduce level of input audio signal to fit with amp of the trig gen?
Many thanks
Page generated in 0.014496088027954 seconds with 16 queries,
spending 0.00740242 doing MySQL queries and 0.00709367 doing PHP things.
