diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
help to mod - Click HERE for Original Thread
leimaster
I have a t-amp from audiodigit.
It's quiet good but bass are not so extended.
Can i do something to solve?
Schematics
Thank You
leimaster
You can see from schematics that it has already the modification of 2.2uF caps....so what else can i do?
pinkmouse
If you search, you will find many threads dealing with this topic.
lousymusician
I started by replacing the 2200 uf capacitors (C4 & C7) with low ESR caps. I used Black Gates because they were fairly easy for me to get, but there are others that should also work well (Panasonic, Nichicon, Rubycon). I replaced Cpump with a 1 uf Black Gate also, I don't know if that made any difference but it was cheap and easy. I'd have replaced C3 also, but that value was out of stock so I let it be for now.
My next steps will be to use a stepped attenuator instead of the supplied pot, and replacing the 2.2 uf input caps with nice film and foil polypropylenes. I have some Sonicaps standing by fr that step.
leimaster
Thank you for replay.
Is your punch bass better now?
lousymusician
The bass is probably a bit better, but the bigger difference was in smoothing out the high frequencies.
Page generated in 0.019829034805298 seconds with 17 queries,
spending 0.00764251 doing MySQL queries and 0.01218653 doing PHP things.
