diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph-x standby mode - Click HERE for Original Thread
yup
My amp will be cycled on and off daily... So I would like to implement a standby mode for my Aleph-x similar to what Nelson said he uses in his amps.
If I recall (guess) correctly, he leaves the power supply powered up and just shuts off the transistors.
I was thinking this could be done by shorting the gate to source on Q1 and Q10 (current followers)-(Grey' schematic) and also shorting gate to drain on Q6a (current source mosfet). Turning off the current source mosfet would turn off Q5, Q7, Q2 and Q11 (diff pair and main output mosfets) wouldn't it?
If so, this could all be done with a small 3 pole relay, without having to switch a large amount of current each time.
Would this cause any type of turn on or off transients that would require output relays? Or should it work fine if a single relay were used to switch them all at the same time?
Please let me know if this thinking is correct.
Thanks,
Jeff
kropf
Shorting the gate to source for Q1 and Q10 could work, but I think I would leave the differential pair powered in standby mode.
Here is another option to spur discussion. You could instead connect the bases of Q3 and Q8 to the positive rail through a 2k resistor in series with the relay switch. That should be enough to turn Q3 and Q8 fully on and shut off the current source.
Jeremy
yup
If the gate-source were shorted on Q1 and Q10 that effectively shuts off Q2 and Q11 (with the exception of what flows through the output to ground resistors (R1, R4, R44, R45) Would that create a possible relative DC offset problem?
does anyone know what transient behaviour to expect by shutting down the current source to the diff pair?
kropf
quote:
Take two cases. If the output current sources are left on, turning off the diff pair current source will send the outputs nearly to the positive rail. This happens because the output gain transistors are shut off and the current from the output current sources will pass through the resistors from the output to ground. If everything is not balanced perfectly, this could cause a large DC voltage between the speaker terminals because you no longer have feedback to control the situation.
In the second case where you turn off the output current sources, turning off the diff pair current source will have only a limited effect on the power consumption, since it runs at only 20mA.
You may need to be careful of the increased power supply voltage when turning off the output because you are no longer loading the transformer (or inductors, with an LC supply filter) or passing much current through filter resistors.
Jeremy
yup
Jeremy,
Thank you for helping me understand a little better, although that does raise one more question in my mind. :confused:
Wouldn't leaving the diff pair on, while shutting off the output current sources, pull both the + and - outputs towards the negative (-15 Volt) rail through the output to ground resistors (via the output gain transistors)? If so, this may cause the same DC offset problem (although smaller in magnitude). I guess you would still have some feedback in that case...
I wonder if there is a benefit to turning off "everything" vs. just the output current sources. It seems that it would be good to leave the diff pair on to keep them warm, but I specifically remember Nelson saying he turned them off in the production units (can't find the exact thread now) I wonder why he chose this method?
Jeff
kropf
Jeff
That's a good point. I should have looked more carefully. I stand corrected, the output current sources and the diff pair current source all must be shut off or else you still get a significant current through the gain transistors (-V rail voltage divided by output to ground resistor value: typically perhaps 15V/30ohms = 0.5amps per half of the circuit). That is a lot less than 4amps per side at 30volts, but I would like to do better.
And thus, we are back where you started. What is the transient behavior?
If you turn of the diff pair CS before the output CS, you may get a loud thump as the feedback shuts down and a differential voltage appears across the speaker. If you turn off the output CS before the diff pair CS, the diff pair controls the thump, then when the diff pair shuts down, the gain transistors should turn off nearly simultaneously without a thump.
Jeremy
Nelson Pass
What I do is shut off the bias to both the diff pair and the
positive output stage, otherwise the outputs go to the - or
+ rails (respectively). The filter capacitance on each of those
circuits needs to be balanced so that they shut down and turn
on gracefully.
:cool:
rsbay
The Aleph X is a 2 stage design. When you shut off both stages were is the standby mode then ?
In my opinion the input diff stage has to keep in normal working conditions and the current of the output stages have to shut off.
Ralph
EUVL
Ralph,
It depends on how you define standby.
In Nelson's case, standby means the capacitors are still charged, but the amplifier draws no current.
If one would like to keep the diff pair on (though I don't see the benefits of doing that), then one would need to shunt the drain resistors of the diff pair, by e.g. switching on the protection BJT's for the -ve rail power FETs. Alternatively, one might also choose to half the current through the diff pairs to reduce the gate voltage for the said power FETs to below their threshold.
But one might also define standby as full current consumption and no sound (just to keep the transistors at constant temperature all times), in which case one only needs to shunt the inputs to ground and disconnect the speakers, say via a relay.
In my own particular case, I did the same as Nelson.
Patrick
rsbay
Hello EUVL,
but what is the benefit if only the power supply capacitors keep their energy? Even if they are empty they get the whole energy back after switch on nearly immediately.
As far as I know, Nelson shut down the bias of the output circuits (and brings the current to zero) in the X600 amp and keep the input amplifier under normal working conditions - and this is for me also the logical way.
In standby mode you want to spare energy, but to keep the important parts of the circuit in their working conditions. What you want to reach is to save time after switch on and to reach best operation (and sound) as soon as possible.
Of course it is the best way to keep the amplifier totally switched on - but than we need no standby circuit. Yes, all we have to do is to short the input to ground and maybe disconnect the loadspeaker.
Ralph
yup
This is good discussion...
For people like myself who will be turning the amp on and off remotely (and frequently) the standby mode the production unit uses has some advantages, mainly low current swithcing.
I have attached a schematic showing a couple of ways of implementing this. What I would like to know is one of these better and why?
The schematic is here: Schematic
Option 1 is shown in red. The relay would swith A, B, & C while the capacitor C11 would be increased to balance the turn on / off thump. This method would allow more capacitance across the CS zenier diode helping to reduce noise.
Option 2 is shown in green. The releay would swith D, E, & F while an additional capacitor would be needed as shown to balance the turn on / off thump
Is one preferable? Did I overlook anything?
Thanks,
Jeff
CheffDeGaar
I implemented a method that works quite nicely. I use relays to add a resistor in // to the bias setting network (pot between base of Q3 and R15/R14 node - and symmetrical parts). The lower the total resistor, the lower the bias.
More details on the attached file in http://www.diyaudio.com/forums/show...5687#post295687
Absolutely no problems since it was built. Keeps the heatsinks gently warm. Adjust the resistor to suit your needs.
yup
Cheff,
Great job on your amplifiers! Your method is definately beyond my capabilities... very elegant.
Is anyone using either of the methods I show in this Schematic?
I have my boards completed and running smoothly on the bench and just wanted to make sure I wasn't making an "obvious" mistake.
Thanks,
Jeff
yup
I have been informed that the PDF is not downloading correctly within a web browser...
right click the Link and select "Save Target as"
I will post it as a JPG when I get home tonight.
Jeff
yup
Here is the schematic in JPG format
Jeff
Look, I'm learnding...
MEnsing
Yup,
Have you already tried one of your options or did you use the option described by Cheff?
Maybe Patrick (EUVL) can describe within more detail his solution because I still don't understand what is the best way to implement this.
Marco
yup
I have been testing (and waiting on final custom transformers to arrive).
What I found worked fairly nice was this: Schematic
As you can see, I break the positve rail voltage to the active current source mosfet gates (D & F) to shut them off and I break the ground reference (E) to the current source mosfet gate to turn off the diff pair and the main output fets. All this is done with a single 4PDT relay.
As far as I can tell, the added capacitance (47uf) across the zenier is a good thing. The 630 Kohm resistor was added to bleed off the gate voltage of the current source mosfet at a similar rate as the active current source (220 uf) caps bleed down.
This setup makes zero noise on my test speaker on power down and only makes the slightest tick on power up. You must actually have your ear to the speaker to hear it.
the transient behavior of the two circuits are somewhat different. I guess because the current source circuit is fading from a different gate-source voltage potential than the active current source mosfets and also because the turn on/off voltage on the 9610’s and 044’s are different too. (please correct me if I am wrong)
In the end, when turned either on or off the absolute voltage (output to ground) smoothly swings towards the positive rail until it reaches about 5 volts and swings back to zero with no overshoot (4 seconds for turn off, 1.5 seconds for turn on). As always, the voltage across the speaker terminals is negligible (well matched mosfets). More capacitance or resistance across the zenier causes it to overshoot towards the negative rail after its initial move towards the positive rail and also increases the time it takes to reach steady state. The way it is now, the diff pair and main output mosfets turn on last and turn off first, so if signal is present, it won’t sound strange during turn on / off.
The circuit modified like this definaltely powers up quicker (1.5 seconds) than it powers down (4 seconds). It may be possible to modify the circuit to improve this performance, but I am fairly happy with this for now.
Please let me know if I any of you see any problems or have any questions...
Thanks,
Jeff
Page generated in 0.054856061935425 seconds with 17 queries,
spending 0.00851154 doing MySQL queries and 0.04634452 doing PHP things.
Please support our sponsor.
