diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Monster Output Stage- 2 KW - Click HERE for Original Thread
lgreen
For those of you who need high power, see the attached output boards, labeled "2KW Power Board." I took these pics with my phone at the surplus store so that's why the quality is awful, but no one ever liked my pics anyway.... :(
6 rows x 11 TO-220 output devices per row (2 rows have 12), placed on a flat copper bar with a hollow copper tube running below the length of the bar. Rubber tubing connects to the copper tubes so that you can put water or some other liquid in the tubes to cool down that bad boy.
The boards include 0.1 ohm emitter power resistors and other components.
Picture #3- top and bottom of 2 boards
lgreen
Picture 08- as close up as i could get with my cell phone, top view
Looks like there are diodes and base resistors, in addition to the emitter resistors, for every transistor.
lgreen
Pic 09- bottom of board, note that the V+ and V- go to copper bars. Based on my quick look, I think that the hollow copper tubes are live, which would make the water (if that is used) inside them live too!
The hollow copper tube is sized such that it is small enough for the TO-220 emitter and base pins to be soldered directly to the PCB.
lgreen
Pic10- top view of 2 boards.
Yes, they have 5 so you can use this for your 10.0 KW home theater system.
Price- $20 for each board. The boards looked to be in great shape too. Now if only we could find some speakers to connect these to.......
jacco vermeulen
quote:
How dare you say a thing like that ! :mad:
TO220 ? => I've gone blind, Ma (TO3)
20 bucks is cool.
lgreen
quote:
20 bucks is cool.
I am an idiot! TO-3!!! TO-3!!! TO-3!!! TO-3!!! TO-3!!! TO-3!!! TO-3!!! TO-3!!!
FYI, the copper you see on the underneath of the board is not a trace, its a copper bar that is attached via rivets to the board. In fact, quite a few things were rivited to the board.
kvholio
no one liked your pics ? then i must be no one.
You're one of the few true diy'ers.
Looks meaty btw. Some industrial application ?
With kind regards,
Klaas
Zen Mod
I hate ya .
:bawling:
:clown:
imix500
It's very possible those were pass regulators used in industrial ion lasers. I've got a crate full of those things somewhere.
Nelson Pass
And what part numbers are those TO-3's?
:cool:
Zen Mod
quote:
:cool:
M (obviously Motorolla)
769521
259-4
7940
http://www.diyaudio.com/forums/show...982#post1070982
:devilr:
lgreen
:cool:
Well I knew someone was going to ask me that, dammit!!! I didn't write the ##'s down. Once again, I'm such an Idiot!
But I'll go back and check, and maybe take a proper picture. I tried to figure out what application this came from by reading all the writing on the board but since I is not too smart today I could not figure it out.
Zen Mod- what the $$$##@ are you talking about??
sawreyrw
You don't have an adequate heat sink. How do you expect the transistors to survive at 2KW?
elementx
quote:
they're water/liquid cooled, hence all the tubing and copper rails...
Zen Mod
like usual- making fool of my self :clown:
that's just copy'n'paste from other thread where I beg for any data for some ancient Motorola darlingtons....
EDIT:
yup........~60 TO3 pieces for 20 bucks........and you didn't even wrote numbers........
you are almost nutzzzzzzzzzzz as I am........... :cool:
jacco vermeulen
Mr Green,
eventhough you're a lousy shot, you're a source of inspiration.
Those units remind me of floor heating hosing.
Regretably not another of my brilliant deductions, i'm in the finishing stage of revamping our 3d bathroom on the top floor. I've put electric floor heating under the floor tiling, switched on the heating in low-mode on tuesday to see if it works.
I just bought a pair of fluid heat exchangers for my next global warming amp project. (you know, the K-thing)
The bias heat of the amps is of a sufficient level for floor heating purposes, 500-600 watts is a standard size.
I've still got the reconstruction of the 1st level bathroom coming, just realised that horizontally there's only 7 to 8 feet between that room and the living. The entire bathroom floor has got to come out anyway, stuffing some braided pressure hosing between the ceiling would be easy.
Distilled water has a very high electrical resistance, though it drops rapidly at increasing temperature to a little less than 20kOhm at 100 C's.
Look Ma, my clock is ticking=>
rolandong
could be another diy'er has gone crazy and turned his automobile radiator into amps.
Page generated in 0.040579080581665 seconds with 17 queries,
spending 0.00827289 doing MySQL queries and 0.03230619 doing PHP things.
