| juanitox |
is this upgrade is still available somewhere and do i must send my unit for it
or is it something easy to do by just changing some chips?
thanks.:smash: |
| Nelson Pass |
Sorry, the upgrade is no longer available. Some of the parts
simply became unobtainable, and now we only suport repair.
:cool: |
| juanitox |
;) thanks master....
it is so good at 16/44Khz ... do you think i will get a better sound
adding a X1 or X 2.5 for the volume control instead of it's own attenuator? |
| Nelson Pass |
If you get enough gain without a preamp, then I would
try that first. Some people report improvements with a
preamp, but these are anecdotal. |
| Babowana |
| quote: | Originally posted by Nelson Pass
anecdotal
You make me busy
Not only with electronics book, but also with Oxford dictionary
:dodgy: |
| juanitox |
;) a last one , how about changing the RCA digital input plug
with a BNC 75 homs plug? when you feed the dac with a 75hom bnc cable for sure..?
thanks .. a new pass addicted. |
| JeffCullen |
I have a D1 and X2 (later version).
When using balanced interconnects into my X250.5, the system sounds better without the preamplifier in the way. There is plenty of gain.
When driving unbalanced gear as in my headphone amplifier, it sounds best using the X2 to convert to unbalanced on the tape outputs. Go figure...
The Ultimate Audio review of the D1 states:| quote: | | The output level is adjustable using a 24-position switch that operates as a differential shunt between the two polarities of the I/V D/A converter. When using the D1 without a preamplifier, it is recommended that the level be set to at least the 11 o'clock position, as there is approximately an 1/2 dB rolloff in the upper frequencies at the lower settings. | I haven't really tested this. I rarely go over 12 o'clock with the D1 straight into the X250.5, it's way too loud!
--jeff |
