diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
A simple speaker protection circuit - Click HERE for Original Thread
Russ White
I have seen a few speaker protection circuits, but they all seem to be designed for a particular power amp, or just don't seem very flexible.
I have been searching the past week or so and found several designs which look workable, and some that kinda scare me.
Anyway, based an what I have learned I have come up with this (this is just the basic schematic, there will be slightly more to it).
Does this look sane?
In particular I am wondering about the zener diodes and the Schottky's I have to prevent the zeners from shorting each other out. I am not sure if what I am doing there is necessary. The idea was to protect T1 and T2 from full power amp rail voltages at the input.
Comments welcome.
Cheers!
Russ
Russ White
Ok so I like this a bit better, the speaker is now at GND when the relay is off.
gbyleveldt
Nice and simple! Have you tested it? The last one I did I connected it to my amp and put a signal gen through it at full taps and tested it down to around 10Hz, where it would trigger.
Yours is a bit different to what I have used in the past, but I can't see why it wont work.
d3imlay
I looked at the relay you're using (Future Elec's site) and noted that it's contacts are only rated for 24 VDC. The JQX115's they list are DPDT and rated for 125 VDC. The ability to break more than 24 VDC is very important. I'm working on a similar design and will give the JQX115 serious consideration.
BrianDonegan
I thnk the Futurlec specs are a bit unclear the way they summarized them. Here are the specs from the Omron G5LB dtasheet (same form factor relay):
Rated load: 10 A at 120 VAC; 8 A at 30 VDC & 10A at 250 VDC
Rated carry current: 10 A
Max. switching voltage: 250 VAC, 125 VDC (30 VDC when UL/CSA standard is applied)
Max. switching current: AC: 10A; DC: 8A
Max. switching capacity: 1,200 VA, 240 W & 2,500 VA
Min. permissible load: 100 mA at 5 VDC
So, you can switch more than 25/30VDC, just with less than 10A current. Although, the first line does strike me as strange: 8A@30VDC and 10A@250VDC?
Anyway, this is the relay we use on the RevC Monoblocks for speaker protection (Siemens version).
AndrewT
I think the 250Vdc is a misprint.
The spec reads correctly if it meant 250Vac
check down to the 1200VA, 240W, 2500VA line.
AndrewT
do you realise you have 4V across the BE junction of t3?
The grounding of the speaker output is far better. It will help blow the amplifier fuse if the arc across the contacts refuses to extinguish. You need rail fuses to take advantage of this.
How can you latch the protection ON after activation? You don't want it chattering ON OFF ON with one supply rail sending offset to the speaker.
I'm not sure the Zeners are quite right.
I think C2 will delay ON till it's too late (or over current T1 and/or T2).
D1 slows down the release of the relay.
You can speed up the release by running it at lower voltage with a dropper resistor and then add a cap from top of relay coil to T3 emitter. The 24V on the extra cap prior to T3 closing fires the relay and then voltage falls to some lower value (above guaranteed hold in V).
Russ White
quote:
Originally posted by AndrewT
1) do you realise you have 4V across the BE junction of t3?
2) The grounding of the speaker output is far better. It will help blow the amplifier fuse if the arc across the contacts refuses to extinguish. You need rail fuses to take advantage of this.
3)How can you latch the protection ON after activation? You don't want it chattering ON OFF ON with one supply rail sending offset to the speaker.
4) I'm not sure the Zeners are quite right.
5) I think C2 will delay ON till it's too late (or over current T1 and/or T2).
6) D1 slows down the release of the relay.
1) I really hadn't finalized the resistor values yet, thanks for spotting that that was pretty high. I have changed it.
2) So at least I got that part right? :)
3) I am not sure how do accomplish this without defeating one of my design goals which is to make the circuit self resetting. I am open to suggestions.
4) Me either, the way I have them they should protect T1 and T2 from VBE > 6V. That was the idea.
5) It could be I will have to test. I have changed the cap and resistor values.
6) I believe I have understood you here, and it makes a lot of sense. Thanks for the excellent suggestion. I hope I have implemented it correctly. I will have to calculate R4 for the correct voltage drop.
Thanks very much for all the input so far! :)
AndrewT
try breadboarding one that works.
When you understand how it detects and hold, and closes/opens the relay then think about redesigning/improving the circuit.
The r2/r3 divider will either prevent t3 switching on or risk killing it if the supply voltage rises a little.
You have implemented C3 correctly. You can now run at more than 24Vdc and adjust R4 to hold in under all normal operating conditions.
That 24V supply can come from ONE diode on the main PSU rectifier bridge with just a tiny bit of smoothing to give near instant drop out on loss of mains voltage.
But, I fear the circuit, as is, is struggling to work.
mhennessy
No, he hasn't.
There's 0.6V, limited by the VBE. Under these conditions, about 0.1mA is available to turn on the transistor. Assuming a (generous) worst-case HFE of 50, that only results in 5mA to drive the relay coil.
I haven't looked up the relay, but I would determine the coil current, then double it. Divide that by the worst-case HFE to find the base current, then double that to be sure. You're trying to saturate the transistor! I would suggest that a value around 22K would be a good starting point - 470K will not work! Remember - you're *not* trying to make a potential divider here, you are providing T3 with base current...
R3 doesn't play that much of a role in this calculation, as it only steals 12uA from the contribution of R2.
C2 provides a power-on delay, but in the event of a DC fault, one of the two input transistors will have to discharge it. Maybe fine for T1, but in the case of T2 doing this, the only means it has to sink current is via the input 100K (R1). I would suggest that this is a problem... For that reason, move the on-delay elsewhere - perhaps add another transistor after T3. This also makes it easier to implement the latch:
Another transistor is needed, forming a simple bistable latch with T3. Some sort of power-up reset is needed, probably a series RC combination.
BUT, do you need the latch? If this circuit triggers, the fault condition will almost certainly persist once the speaker has been disconnected. In fact, the DC fault voltage will probably rise once the OPS has been relieved of supplying many amps to the poor voice coil. You are correctly sampling before the relay contacts :)
For what it's worth, I implemented this DC-detect circuit in my quad LM4780 amp, only I interfaced it to a PIC (overkill, but the PIC was there doing other things). During testing, I found it works well, but you need to avoid trying to pull too much current from the collectors of the transistors if you want the detection thresholds to remain symmetrical (although C1 helps, of course). Which is what could happen with this simple circuit if you stick with 3 transistors (so perhaps a Darlington would be better for T3?)
Mark
AndrewT
Thanks Mh,
I didn't see the constant current through r3!
mhennessy
Thanks Mh,
No worries ;)
BTW, you're right about the zener diodes - as shown they only work as normal diodes anyway. I'd omit them and just connect the base of T1 to the emitter of T2. No worries about the 6-7V reverse-VBE damage as the other transistor clamps this to 0.6V.
Another BTW - much as the power-saving relay scheme is a good idea, it might not function in this circuit because C2 causes T3 to turn on slowly. He could fix this by adding another transistor to make a schmitt trigger... I've used current sources with relays, but this has been more about varying supply voltages than saving power... (a good idea if using the half-wave/small C scheme you rightly suggested)
Douglas Self did an article about relay release speed, conclusions were pretty much common sense IIRC. Don't forget the delay caused by the input RC filter (I guess about 65ms currently)
Mark
Russ White
Excellent feedback Mark and Andrew!
I very much appreciate your thoughtful advice.
Here is what I have now based on your inputs.
Any further feedback is greatly appreciated.
R4 is there to adjust the sensitivity of the DC protection.
:EDIT: schematic was screwed up. :) Fixed.
mhennessy
Hi Russ,
This looks better than before, and will probably work ok. Comments?
R4 probably won't affect the sensitivity in any desireable way (because it depends on the HFE of the transistors, and will affect the turn-over frequency of the input filter). It's better to have lower values here because the input transistors will need some current - 100K is as high as I'd go.
R3 probably isn't needed.
R7 definitely not needed.
The circuit doesn't self-reset very quickly because there's nothing to discharge C2 (apart from the intrinsic diodes in the op-amp - not good!). Add an 1n4148 in parallel with R2, pointing "up"...
C3 would probably be better if it was 100uF, perhaps more. Testing required...
The circuit still suffers from having to discharge the power-on delay cap via the input transistors (and R1). This morning I quickly sketched up a circuit that uses a PNP emitter follower after the input pair to get around this problem. It also uses a current source to drive the relay. I've hacked around your latest diagram to show you the idea...
There's an optional DC-fault LED indication, and longer power-on delays are possible because you can use large values of C with no issues. Whether it's better for your application is obviously for you to decide...
Hope this helps,
Mark
Russ White
Wow thanks Mark, those are some good pointers.
What would you think about something like this?
soundtech
Not wishing to undermine all your hard work, but Velleman have a kit for this.
Part # K4700, the assembly manual with schematic are available for download on their website.
www.velleman-kit.com
Paul
mhennessy
Hi Russ,
That looks pretty good. IC1 will ensure the relay is snapped on quickly, allowing the power-saving scheme to work. I might have added another transistor to my last circuit to achieve that, but it's personal preference thing. I like transistors!
Now, C2/R4 can be lower/higher respectively. I chose those values in my circuit to ensure sufficient base current in the relay drive transistor. Certainly 22u and 100K would be where I'd start now...
Regarding IC1: Watch the total supply voltage (assuming it's fed from a half-wave rectified version of the main transformer). Obvious, I know...
Be sure your chosen device is happy to have its inputs close to the supply rails (I've been caught out in the past with the TL08x devices). It might be worth trying a resistor (1-10K, say) at the non-inverting input of the op-amp so that the input doesn't see such a low impedance close to the rail (some devices can be funny about this)
It might help to add a feedback resistor to IC1 to give it schmitt action. Say 100K-1M between out and +in, (note you'll also need to add the input resistor mentioned above). This will ensure the o/p changes state cleanly with no spurious transitions (perhaps caused by the unregulated supply). Any funny business happening at this time might affect the operation of the power-save relay drive circuit.
Time to start bread-boarding ;)
Mark
mhennessy
Paul
Yes, I know this kit well. While this might solve the problem, no-one here would learn anything from just buying a kit.
Also, it's somewhat complicated, don't you think? Just look at all those electrolytic capacitors waiting to dry out!
I don't know if Russ is planning to add this to his product range, but it would certainly be a compact and economical alternative to the Vellemen offering ;)
Mark
Russ White
Paul
This is not about "obtaining" a solution, but rather designing one. There are more than a couple designes I could directly copy, but I wouldn't learn anything that way. :) This is the joy for me, the journey, not just the destination.
t has been very fun so far. :)
Russ White
quote:
Originally posted by mhennessy
Hi Russ,
Mark
Hi Mark,
Once again very good input! Thanks!
I was thinking I might add an additional zener on the non-inverting opamp input to limit the voltage there to below the rail voltage, maybe something like a 18V zener.
I will add the resistors as you say, I was actually thinking the same thing, just had not fleshed it out that far yet.
I will probably use something like a LF411 for the circuit (since I have a bunch of them and they are relatively cheap).
Cheers!
Russ
AndrewT
do you have any comparators?
I think they would work here instead of an opamp.
The whole detection thing could be done with a pair of comparators set up as a window comparator. Just one dual 8pin chip and a switching transistor pair.
Worth breadboarding to see the difference (if any) from your proposal.
mhennessy
Interesting thought - in this context comparators are the same as op-amps, only their outputs are open-collector (not all, I know). So connect the outputs together for a wired-OR connection, use this to discharge the power-on delay capacitor...
The only "But" I can think of is that a single transistor following on from this delay-cap will get us back to an earlier problem, whereby if the transistor turns on slower than the relay power-saving capacitor discharges, the latter might not perform its function properly. But I've never played with this particular variation myself, so maybe I'm worrying about nothing...
Of course, you could add another dual comparator to do the power-on delay separately, and use the spare section as an over-temperature detector ;)
Russ, if you put the two resistors around the op-amp, you probably won't need an extra zener. Glad you're enjoy this :)
Mark
mhennessy
Just thought of another one - you have to create a -ve supply for the -ve threshold of the window comparator, not to mention the supply for the chip itself.
Not a big deal, but an extra diode/capacitor/dropper resistor...
There's also a chance that the max supply voltage the IC's run from could become an issue, requiring supply regulation. That's why I generally prefer transistors in these sorts of roles - no such limits if you choose the right device, and no cost-hikes either (unlike high-voltage op-amps!)
Mark
Nordic
I don't think the speed thing is such a big issue...
For instance looking at the mauro penasa amp, he has a check along the line of +xVDC for y seconds and another set for the negative rail.
I mean even low frequency sounds like a 10hZ tone could also be called DC, so haveing too fast a response is not nessecarily good is it?
Russ White
Nordic,
As you know i know that circuit (MyRef) inside and out. This is actually significantly different in multiple ways.
The place we want things to happen very fast is when the relay switches when DC "is" detected. That is why the schmidt trigger is there as well as the R and C around the relay coil. The faster the relay witches to GND the faster the speaker is relieved from the DC.
The speed at which the DC is detected is determined by adjusting the RC filter. That would be adjusted to be reasonable for the application with some general starting value which should work for most amps. The triggering of the detector will be determined by the voltage and frequency of the signal coming from the amp's output.
Cheers!
Russ
Russ White
I made a simple PCB (will post later)
Here is the circuit I settled on.
Since the opamp will not swing all the way to GND I added the diodes and resistor at the output.
I test the circuit with 35V on input and it takes about 5ms for it to kick off the relay. :) Better than I hoped.
Cheers!
Russ
AndrewT
now test it with AC signals.
try full voltage 20Hz and progressively lower the frequency until the filter lets through enough signal to trip the relay.
If satisfactory, then try to see how little DC is needed to trip the relay.
My targets would be
1. pass 10Hz full voltage and stay untripped.
2. detect 1.5Vdc and trip.
Nordic
Much appreciated Russ...
Russ White
My targets would be
Hi Andrew. :)
Seems to easily pass those tests.
Been running only with 35V rails though, will try higher rails later. I can actually get it below 3hz without issue at these rails.
1.5Vdc does indeed trip it, after a half second or so. (simple AA battery enough to test this).
The nice thing is that the Schmitt Trigger with positive feedback does its job nicely keeping the relay from chattering in the gray areas.
Cheers!
Russ
Russ White
Here is the supply circuit I am thinking of using. :)
Easily tuned for 110 or 220V mains.
No dependency on amp transformer at all. :)
The circuit will be adjust to provide a constant load even when the speaker relay is off.
Cheers!
Russ
AndrewT
Hi Russ,
now for a bit of tuning.
In my opinion, we want FAST detection with minimum false triggering on music and sound effects.
The DC detect will get faster as you reduce the input RC time constant.
Reducing the cap will alter both the DC time delay AND increase the minimum frequency that passes without tripping.
Your 500mS and 3Hz is maybe a good compromise, but try pushing this to become a little faster.
Finally, what about latching?
What if a semi goes short circuit and passes DC current to the speaker? The relay pulls in? What next? It must not reconnect the speaker while the fault still exists.
Will the circuit hold the speaker relay open at amp start up and delay connection until the amp output levels have settled (in those first few tens of mS)?
d3imlay
Cheers!
Russ
If I understand the proposed power supply right, the negative terminal is one diode drop away from the line voltage. The detector ties the output ground of the amp to the negative DC of the supply. Assuming the chassis of the amp is tied to the output ground, that will put the chassis of the amp one diode drop away from the line voltage and pose a serious health risk. Am I missing something?
Russ White
quote:
You are very right. :) It is probably not advisable at all as it is. I use this scheme for my soft start, but In that situation a relay and amp's transformer are isolating the circuit from the user. So using this circuit the same way may not work without some safety precautions, like fast blow 500ma fuse or something. The draw on the circuit is only about < 23ma.
Russ White
OK, I think I have an idea, I could separate the protection PS from the AMP PS via an optoisolator. That should keep every thing well isolated. I will see what I can work out. Also the case should be connected to mains earth.
Russ White
How about something like this. :)
Russ White
Errrr... ignore that last one. It had some major flaws. This one is better. :)
Cheers!
Russ
mhennessy
Hi Russ,
Hi Andrew,
The input filter design is always a compromise, and the best way to improve on this is to choose a 2 pole input filter - that's what the Velleman kit does. One has to balance this against the increase in complexity - this is one area where reliability is key!
I've already spoken about latching (post #10), and I would again suggest that it is not necessary. Can you think of a situation where the DC offset will dissapear once the speaker has been disconnected? I can't (that's not to say it's impossible, of course!). But, looking at the latest schematic, it would be reasonably straightforward to reconfigure Q1/Q2 as a bistable latch...
Yes, this circuit does provide power-on delay - R4/C2 do this. Much has been said about the need to quickly discharge C2 in the event of a fault - hence the PNP EF (Q3)
Best regards,
Mark
Russ White
Hello Mark,
Thanks for articulating those points. I agree with you on these.
Have you looked at the optoisolated version? It has one key advantage that the relay PS is completely isolated from the audio signal(and GND). But it has one key tradoff, that is that the turn on voltage for the LEDs is around 1V as oppose to .6V for the transistors. Keep in mind, that is just the SPICE circuit, the real one will have some additional parts (like the discharging diode for the delay cap).
Cheers!
Russ
mhennessy
Hi Russ,
I've used capacitive-dropper power supplies before, and they're a mixed bag. Certainly not for the inexperienced constructor - so while this is fine for your own use, I'm not sure if I'd do it in a kit... The one published project on my site that uses one also has several warnings and disclaimers!
It would certainly be easier to use the AC from the transformer, as earlier suggested. If you're worried about accomodating a range of supply voltages, simply change the relay drive to a currect source. The rest of the ciruit can be powered from a zener and dropper resistor...
The main worry I have with the latest circuit is the detector sensitivity. The LEDs need around around 1-2mA (perhaps less because the collectors don't need to sink much). But 1-2mA through a 20K resistor suggests a voltage drop of 20-40V. So you might need to buffer the filter output, which creates more complexity.
Having said that, opto-couplers can be really usefuly building blocks, even when you don't need to isolation properties. I've seen this circuit used plenty of times before :)
What else? I like the connection of R1, and was going to suggest it myself earlier (if you wanted to save a 1n4148 when not using the optional DC fault LED). It makes the base look like a current source (0.6/500K - 1.2uA which is probably a bit low here for good noise immunity - earth those opto-bases!). FWIW, R10 can be omitted. R4 needs the parallel diode to discharge C2. Not sure why you have D5? Consider replacing those series diodes with a zener or LED to reduce component-count (if it matters). The two output transistors are obviously there to keep the supply voltage roughly constant, but this strikes me as wasteful. A consequence of the capacitive-dropper PSU. These could easily form Andrew's latch :)
Not sure why Q1/2 are different types - they both switch the same load. R12 is a bit high, probably... Never used an LT1224 before, but it looks massively over-spec'd to me. Was that selected as convenience in the simulator? Personally, a good old 741 is what I'd use here - basically anything that's cheap, as a circuit like this shouldn't make any demands of its components...
Don't know if this helps?
Mark
Page generated in 0.12121105194092 seconds with 17 queries,
spending 0.01541924 doing MySQL queries and 0.10579181 doing PHP things.
