diyAudio.com diyAudio Forums Archive > Top > Source > Digital
filter construction of dir1703 - Click HERE for Original Thread
takashi
hi,
i have done a pcb of dir1703, i find that the filter construction is different between the datasheet (c7, c8, r2)and EV board user menual(cf1 cf2 and rf1).
which one is correct? or both can be used?
thanks
Brian Brown
Use the filter example shown in the DIR1703 data sheet:
R2 = 1.2K Ohm
in series with
C7 = 0.068uF
and
C8 = 0.0082uF
I believe the schematic shown in the DEM-DIR1703 Instruction Manual is wrong. Besides the fact that it doesn't match the part's data sheet, the values don't make any sense from a functional standpoint.
Also, this is further confirmed by other TI eval boards using the DIR1703 (such as the TAS5100EVM) that show the same filter values as the data sheet.
Brian.:cubist:
takashi
thank you very much, Brian Brown
and one more question, can i connect the coxial/BNC s/pdif to Din(pin20) of DIR1704 directly?
Brian Brown
quote:
No.
Unlike many of the Crystal parts, the DIR1703 requires an external receiver circuit.
This makes the circuit a little less convienient to design, but using an external receiver makes it possible to achieve better impedance matching to the incoming line and also better noise rejection.
Brian.
Page generated in 0.022743940353394 seconds with 17 queries,
spending 0.00924516 doing MySQL queries and 0.01349878 doing PHP things.
