diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Paralel CS8420 & CS8414 - Click HERE for Original Thread
A'af
Hey folk, did you have a plan to use CS8420 & CS8414 paralel, I need a simple configuration, want to use upsampling and true 24/96 feeding to my DAC using DF1704 and PCM 1704
costiss
yap.. elektor electronics have published an upsampling unit based on crystal cs8420, providing both i2s and s/pdif outputs you can find the pcbs in www.elektor.co.uk under the numbering 010014-1
A'af
Thanks costiss but if you be pleased I'm to plan use CS8420 and CS8414 simultanously in one PCB, perhaps w/ some logic controller and sensing wich input being use, other way want use input 16/44 data upsampled and true 24/96, btw the link is dead, thx for companion and attn
costiss
http://www.elektor-electronics.co.uk/ sorry..wrong link
this upsampling unit when loaded with 96kHz S/PDIF signal acts as a bypass BTW imposes no change other than the S/PDIF->I2S conversion - no reason to use the cs8412..
costiss
the pcb is tofind in issue no 298 april 2001
A'af
Thanks costiss, how did you know when fed by 96kHz this CS8420 by passes the signal, I'll check the data sheet also, btw from elektor can download the pcb, is that good I'm not really looking the design, once again thx
costiss
elector published some performance tests along with the article....
yves
costiss
what are the details for the inductors used?
Any chance of getting the complete article?
Thanks very much for the info
Yv
A'af
Yeah Costiss, if you dont mind can you put that article in this forum or at least by email :)), cheers
"Single Ended Single Driver Single Minded"
btw r u also a WRC fans?
costiss
unfortunately the article is in greek :-( - i dont have the english issue - should be may 2001
costiss
yves the inductors are standard smt units, no more info about 'em
Page generated in 0.033727884292603 seconds with 17 queries,
spending 0.01533270 doing MySQL queries and 0.01839519 doing PHP things.
