| d3imlay |
| What is the preferred alternative to the standard 25 amp bridge? My application is for a 200 watt amp. I can use either discrete devices or a full wave bridge. |
| edl |
If that's a mono 200W/4ohm-RMS amplifier, then let's use a 15A/200V bridge. For stereo 25A/200V.
If it's a 8ohm amp, then use 10A/400V for mono, or 15A/400V for stereo.
Regards, |
| d3imlay |
| Fast recovery? Schotky? |
| XEAGLEKEEPER |
| A 35Amp 400v would be my selection $3.85 thru AlliedElectronics |
| Leolabs |
| Unless you can hear the differences,otherwise a 35A bridge will do the job rather than using the fast recovery or schottky. |
| XEAGLEKEEPER |
| Thats the bridged rect. I used in both of my ESP P101's:) |
| edl |
| quote: | Originally posted by d3imlay
Nor fast recovery, nor schottky. Use "normal" bridges. |
| AndrewT |
I have started using RC snubbers across each of the four diodes in a standard 25A bridge in power amps upto 300W into 4r.
I have always used caps from line to return on the primary, the secondary and the DC side of the PSU.
They seem to be quiet. |
