| JDeV |
Just a day late but merry xmass to each and all - and a happy new year to come.
I just completed and fired up my X-BoSoZ - which is now the proud bride of Mr.Aleph30 ;) [BoA] ??
http://www.diyaudio.com/forums/show...&highlight=jdev
Unfortunately I did not 1st build std. BoSoZ as planned because of using stripboard and the hassle of removing and rerouting jumpers (always a pain with stripboard). Anyway I did compare to org. setup which was CD player direct to A30. I use unbal. IN, bal. OUT. Only deffinate differance I can tell is that A30 got more - deeper base now and are sligthly more crisp - if you can imagine crisp :cool: , and now I have full range vol. control - loud enough at least.
Here are couple of pics. |
| Mad_K |
Very nice!
What volume control are you using? |
| macka |
Well done,
Is that a TDK attenuator?,
Does it have an active current source (simple FET type)?
I will also look at the X mod to my BOSOZ over the weekend.
regards
Macka |
| Henrik |
Hi J Dev!
Verry nice looking!
At what PSU-rail voltage du You run this new born Chrismax child?
:xmasman: |
| JDeV |
Thanx for all the compliments.
I use 2 x stereo pots, Alpha - 10kohm, which I ganged for 1 axis. This was the best I could do with local components. After reading the tests done by Henrik, (http://www.diyaudio.com/forums/show...k&pagenumber=28) , I decided not to use any CCS, but just ground -IN on the earth lug of the input RCA plug. My PSU gives a nice 60.5V on the rails, as recommended by the :wiz: himself.
Thanx again to Henrik, Ralf and the other X-BoSoZ developers for all your time, effort and advice on designing this circuit. Guys like you and the others with the same abilitys , give guys like myself and others with the same disabilities realy alot of pleasure and fun :up: :up: :up:
1 last family pic: |
| Bricolo |
sweet :) 2 X-BOSOZ in one day.
Is there any "final" (or latest, approuved, anything you want) shematic? |
| akira |
It should be the one on page 17 in the X-SoZ thread. But henrik could confirm ...
[off topic]
Are u the same Bricolo than the one on the HFR forum in France ? |
| Bricolo |
| quote: | Originally posted by akira
[off topic]
Are u the same Bricolo than the one on the HFR forum in France ? | It's me :) |
| Charles BL |
| What's the pedigree of your pretty x-Bosoz chassis? |
