diyAudio.com diyAudio Forums Archive > Top > Market Place > Vendor's Bazaar
Nichicon Muse capacitors! - Click HERE for Original Thread
Minisemi
www.minisemi.com
EdT
Hey, Luc has a good selection of audio grade Nichicon caps. Great communication and even free delivery if you are around the area ....recommended !
wisinskt
How much of an improvement will the Muse caps be vs. the VX(M) caps in a power supply such as the Linn Valhalla?
Minisemi
Hi!
VX series are not audio grade they are general propose but have rated voltage up to 450V,something that you don’t have in the’’Muse’’series maximum rated voltage is 100V mostly.Depends of your rails power of your PSU?But Muse series improved frequency response,coefficient, sound, acoustics and harmonics etc.There are designed for audio equipment.
Thanks!
jeffry_widjaja
Hii
at the first time i would like to order your fx 2200uF
50F but now it is out of order
can you order 2200 uF 50 V im glad if it is from FG family
maybe i buy 10 pcs
pls inform
jeffry_widjaja
i have address in usa
no need send it to Jakarta
jeffry_widjaja@yahoo.com
Minisemi
Hi Jeffry!
You can order directly from my website www.minisemi.com and yes the 2200uF-50V from FX series are out of stock and will be out of stock forever because Nichicon stop production and discontinued all the FX family and as been replaced by the FW family. We have stock for FW,they are gold color same size and quality of FX.Best regards!
Page generated in 0.033363103866577 seconds with 17 queries,
spending 0.00827861 doing MySQL queries and 0.02508450 doing PHP things.
