diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Short the Output of an Aleph X - Click HERE for Original Thread
rsbay
Hello,
I want to implement a relay to short the output of the Aleph X amplifier during run up and as a security device for my loadspeakers when the differential offset gets to high.
There are two ways of doing it :
1. short the plus and minus output to ground
2. short the plus and minus output together
Can I use one of both ?
Ralph
Netlist
A carefully build and aligned AlephX should be stable within the 100mV range offset.
The McMillan resistors and the big output resistors to ground will greatly help in stabilizing the DC.
Besides that, I’m not sure relays are happy with switching DC voltages in the long run.
As far as I know, there are no reports of AlephX’s who ever damaged speakers so I’d concentrate on good and careful alignment instead of output relays.
/Hugo :)
Duo
Or stick a non-polar electrolytic cap in series with the speaker.
-- Yeah... I know.... sorry... ;)
EUVL
Ralph,
Short plus to minus. Check amp stability with shorted outputs with an oscilloscope (i.e. it does not oscillate).
And make sure the relay has sufficient current rating.
I use automotive relays.
Patrick
harryeng
Hi Ralph,
I am building an Aleph X myself, and am just starting on DC protection.
A problem is that most DC protection circuits are not differential, but measure DC against zero. The only one that claims different is Euvel. Check out his post:
http://www.diyaudio.com/forums/show...4018#post434018
When you short-circuit + against - you have no in-line contacts. One of the relays that can handle the DC load is: Amplimo . Check under Amplifier Modules, down at the bottom.
Please keep us "current" with your solution.
Greetings, Harry.
Zen Mod
quote:
Originally posted by harryeng
Hi Ralph,
A problem is that most DC protection circuits are not differential, but measure DC against zero. .......................
Greetings, Harry.
try uPC1237 for that
rsbay
Thanks for the informations - I will shorten + to -
I think about using a microcontroller and measure the voltage of both output against ground. Than I get the information about the differential DC offset over the load and the absolute offset of each output.
Ralph
EUVL
uPC1237 measures DC offset to ground, so not differential.
Of course you can change the input circuit, but as Harry pointed out, I have already published a full differential circuit. It works without a hitch for 4 years (not that I needed it at any time). It is much easier than a µP, and I do not particularly like HF circuits near my analog amp. You need to adapt the circuit a bit for different relays (in terms of coil current).
If you want readout, 2 (or even 3) multimeters from Reichelt at 6 Euros each is the easiest solution.
And the quality of the relay contact for a shunt protection is not important. It just has to handle a hugh pulse current (say 200A min.). You can also short to a small power resistor (say 0.1 ohm 50W) to make life a bit easier for the relay.
Patrick
Zen Mod
quote:
download pdf and you'll see (if I understand it correctly ) that 1237 don't need gnd for sense.
both legs for sensing (L and R in stereo connection ) are virtual ground .....L for R and vice verse;
perfect for diff use
EUVL
When Pin 2 is 0.7V above pin 5, pin 6 will go open, turning the relay off. In operation, Pin 6 goes to Gnd (=Pin5).
In the circuit published, the 56k resistors plus the 330µF cap form a low pass filter to isolate the DC component of the amplifier output, which if more than 0.7V will trigger the protection circuit.
So let's take your suggestion and connect the +ve output of an Aleph-X to the Rch point in the circuit, and the -ve output to the Lch point. A 2-V common mode absolute DC will certainly trip the relay, but a symmetrical differential DC across the outputs will do nothing, as the 56ks form a pontential divider which gives you a nice 0V at the +ve pole of the 330µF cap.
Or you have something else simple in mind which does not require a differential amp (opamp or otherwise) ?
Patrick
Page generated in 0.14389395713806 seconds with 17 queries,
spending 0.09586573 doing MySQL queries and 0.04802823 doing PHP things.
