| BPA200, replacing LF412ACN with? - Click HERE for Original Thread |
| CJ900RR |
Thinking of constructing a pcb based on the BPA200 in Nationals AN1192.
My simple question is, can I replace the LF412ACN with LM4562 straight forward, or do I have to re-calculate the values on other components to?
Best regards, Calle... |
| tlmadsen |
HI Calle
Normaly you should be able to replace LF413 with all most any other DUAL op-amp, but why would you. ??
It is part of the DC-servo, so the only real important parameter is its offset. Something like the AD712 (I think it is called) might be better in that respect.
Your DC-servo will not sound "better" by putting a fancy Dual op-amp into it.
I have no problem using a DC-servo (see some of my other replys), but people that don't like them are normally against the hole "topology" more than a single component.
Have fun |
| peranders |
| The servo opamp will feed back audio signals up to 500 Hz to 1 kHz. So it must be good in those frequenies which most decent opamps are. Over 100 Hz a very small part of the audio signal goes through the servo. As Thomas says almost any opamp will fit. Personally I chosen an AN8620 as a buffer + servo and for the servo part it's massive overkill but it's nice with 80 uV offset! :) You can see my implementaion of AN-1192 at my homepage. |
| peranders |
| The servo opamp will feed back audio signals up to 500 Hz to 1 kHz. So it must be good in those frequenies which most decent opamps are. Over 100 Hz a very small part of the audio signal goes through the servo. As Thomas says almost any opamp will fit. Personally I chosen an AD8620 (or OPA2134) as a buffer + servo and for the servo part it's massive overkill but it's nice with 80 uV offset! :) You can see my implementaion of AN-1192 at my homepage. |
| CJ900RR |
Thank you for your answer. That was what I thougt. And today I found some LF411 and LF412 stuffed away at my work. But they where labeled only CN, not ACN. But what I can see from the datasheet its only V-rating that difference from the ACN-version... I will try them first.
But I have a new question. How do I do with the mute-part of the LM886. Do i need mute-resistors and cap's for every LM3886, or do I need only one to mute them all?
| peranders |
The mute resistor is very important. No resistor = MUTE.
10k is a normal value but I did chose 33k + 100 uF just because I wanted a longer delay _with_ a 100 uF cap. If you don't want the delay, just omit the capacitor but it may be a good idea to have it since you have a DC servo which may create a small startup transient. Please check the datasheet and the diagram over this mute resistor. You should have more than 0.5 mA from that pin. |
| peranders |
| Notice also my comment there about the measurements. |
