diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph-X parts list - Click HERE for Original Thread
vdi_nenna
Grey and/ or John Inlow,
I got the boards yesterday in the mail, thanks John.
I do have a question. If I pull down the schematic Grey put out on 5/24/02, will the parts on the schem. match the board's screen? I tried to search for a parts list but found none under Aleph X.
Thanks and Merry Christmas,
Vince
:santa2:
GRollins
Merry Christmas, fella,
I never got around to posting a formal parts list...or at least I don't remember doing so. Probably should, I guess. Considering that I've got myself involved in the high-powered Aleph-X dingus, I'll have to dredge around and locate the schematic (the version I posted and the prototype had some differences...). If I can keep my focus, I'll get you up a shopping list.
As to what the boards take, I dunno. You'll have to ask the board guys. I'm not sure what path they chose.
Grey
carpenter
There's a parts list on the alpha pcb thread that follows Grey's original specs (fairly certain). The latter schematics I posted (same thread) include Grey's follow ups and are not posted in the parts list. If you use the latter schematics you'll need to modify the parts list. The only changes are the two resistors that accompany V2.
John
carpenter
here......
vdi_nenna
You guys rule!
:D
Bricolo
the parts price would also be nice :)
grataku
Bricolo
should we buy the parts for you, too?? ;)
A note on the part list: R19-29 should be 20 K max (per Nelson comment) I am using 10K. 68k is too much.
the FDB res can even be 200K and resistor to GND 100 ohms.
5 or 10 pf in the feedback loop should work.
The original IRFP044 should be better here. They have higher transconductance. IRFP140 should work as well.
Bricolo
would be nice ;)
carpenter
Hi grataku,
What happens if you run 68k on R19/29?
grataku
What happens if you parallel a 100 ohm and a 1000 ohm resistors? You can get rid of the 1k ohm because it does almost nothing.
hifiZen
Yeah, I've been meaning to post a new parts list. There is one posted in the Veta/rev1.0 board thread, although it's for the Beta boards. Parts list for the rev1.0 board is pretty much identical, save for the correction to R19/29. The rev1.0 schematic is just slightly different as well, allowing a bit more flexibility in the connection of the current source to GND or -V.
Unfortunately, I'm on vacation, and relatively poor internet access until I return in January. At that time, I'll post an updated BOM and schematic in .pdf format.
carpenter
what is the impact of using the lower resistance value resistor instead of the 68k?
hifiZen
Well, I haven't done any simulations or calculations, but from previous experience using mosfets for diff pairs, I know that they have a fairly high input capacitance. What do you get with a high impedance input and a bunch of capacitance? Low-pass filter! I imagine if the input impedance is too high, you'll end up with too much roll-off in the extreme treble, maybe even creeping down into the audible range. Lowering the value of R19/29 reduces the input impedance, since that 68K is effectively in parallel with the other resistors connected to the input node, excluding the 220R (since it looks into a high impedance).
carpenter
Chad, I appreciate the info. FWIW, Shawn Wessol's AX was plenty bright sounding and I heard all kinds of detail in the upper range; far more than my Zen. I'm not certain if he changed the resistors mentioned here.
macka
John,
My order arrived in the mail today and the boards look very smart.
Well done mate, you are a champ.
I particularly like the references on the board to Grey Rollins for his credit to the design......where would we be without him!
This should keep me busy for quite a while, the journey continues.
Cheers
Ian
carpenter
Thank you, Ian.
GRollins
Being both silly and goofy, I have discovered that I placed a BOM (Bill Of Materials, i.e. parts list) in the original ZIP file on the first page of the Aleph-X thread. I don't remember doing so, but...
Grey
Jean
Anybody finished a pair with the above listed bom and its in working order ?
thanks
Page generated in 0.2525110244751 seconds with 16 queries,
spending 0.22070622 doing MySQL queries and 0.03180480 doing PHP things.
