| takashi |
where can i find (buy ) DF1700?
i have search in www.ti.com, but i can't find and data sheet
any one have data sheet?
and also, can it be replaced by df1704/06 or any ? |
| rfbrw |
The DF1700 is the same as the NPC SM5813. This has also been discontinued but you can find the datasheet here
http://www.npcamerica.com/Datasheet...ucts/sm5813.pdf
While it is possible to replace the DF1700 with the DF1704/6, it would require a fair amount of work as the two chips are not pin compatible and the DF1704/6 is a surface-mount device.
NPC do list the SM5841D as a replacement for the SM5813 but again the two chips are not pin compatible. |
| takashi |
but where can i buy those ic?
i think it is difficult to find... |
