diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
New build of Aleph P1.7 preamplifier - Click HERE for Original Thread
t3447ml
For your consideration, my Aleph P1.7. I would like to thank Nelson Pass and everyone else on this forum for making this hobby accessible to me, Kristijan Kljucaric for the main and power supply boards and Mikkel Simonsen (Dantimax) for the 64 step relay attenuator.
t3447ml
Front Panel
t3447ml
Rear Panel
dw8083
Very nice!
Where did you get the chassis and the attenuator board?
How are you enjoying the sound?
-David
mlloyd1
and where did you get the feet?
indeed, very nice looking.
how do you like the sound?
mlloyd1
quote:
Originally posted by dw8083
Very nice!
-David
folkeb
Hi!
Very nice job indeed! What value (resistor) did you use for the Relvol3 board? Did you put the relvol3 on the output or input?
Best regards,
Folke
t3447ml
Chassis and feet came off of a junked amplifier I pulled out of the trash.
RelVol3 is on the output set for 1K resistance.
I'm not ready to comment on the sound yet. The system is totally new, consists of an Aleph-X and back loaded Fostex FE108EZ horns. All of which have there own issues. The Aleph-X runs too hot and the horns are weak on bass.
folkeb
What capasitors did you use on the main board and PSU board? I was thinking of going with BG Ns if nothing else is recommended...
Best regards,
Folke
t3447ml
Folkeb, thanks for your question, it causes me to recall the many happy hours I spent looking for the right capacitor. I first looked for a metallzed polyprolpyene cap but could find none that would fit the board I was using, as I recall it has a spacing of 27 mm. What I ended up with are 10uf Panasonic ECQ-E(F) metallized polyester caps.
At the time I has not familiar with the BlackGate N caps. With what I have read here in this forum I would be inclined to use them if starting this project now.
folkeb
Alas, the everlasting discussion, what cap to use? I have heard some say that the MKP caps are better than the BG N's, but then others say otherwise. This leaves me... not that wise!
Have you compared different caps, or was it only a question of size?
Best regards,
Folke
folkeb
Where can you get the panasonic caps?
F
2002tii
Farnell have Panasonic caps.
Only downside is that they do not take private orders.
Has
Which control unit from Dantimax you bought it? It seems it's only Control2 CPU board without front panels.
spzzzzkt
The board attached to the front panel which has a rotary encoder attached looks like it's a VolControl2.
http://electronics.dantimax.dk/Kits...1016844882.html
cheers
Paul
classalpha
i intent to build the volume control the hard way.
Using all discrete, off the self components.
Part lists:
optical rotary switch (2bit)
8bit up/down counter
8bit DAC to drive a display meter
3 to 8 multiplexer
relays,resistors............
spzzzzkt
That doesn't look like a list of discrete components to me :dodgy:
Or are you intending to make discrete versions of the logic circuits?
Paul
classalpha
No no no...........
that will be too many component.....:)
what i meant was, i do not intent of using any controller with C-programming. instead, i will do it using logicgates....... :)
I guess my meaning of 'discrete' was slightly out. hahaha.....:D :smash:
spzzzzkt
that is a pity...
i would have been interested to see how an all discrete relay volume control would work :D
felix the cat
quote:
can you tell us now the sound of Aleph P? Please describe the sound, and can you compare the sound of Aleph P with other preamp? Thanks.
folkeb
I must admit I haven't tried very many preamplifiers to compare the aleph P to other products. I recommed you read the reviews of the commercial product for more info. What I personally have experieced is that there are several tweaks that improve the sound, e.g. using Siemens sikorels 1000uF and BG N bypassed with MKP1837. However, the aleph p is a perfect match with my aleph 1.2s, my previous Electrocompaniet 250R and a friends Dynamic Precision A1. I am feeding the Aleph P with a DDDAC (4.7uF decoupling cap).
With regard to dantimax I must say I am very disapointed! Both my friend and I used the relvol3 with input and controller, they have now both failed within a few months. Also there seems to be several ground loops in the design, as in noise.
It may have been bad luck, but both sets had the same issues.
In the end I have replaced the dantimax with a standard alps pot for the time being.
Anyone else having issues with dantimax?
F
spzzzzkt
folkeb,
not sure about the relvol3 failures being typical... i've been using a relvol3, input2 and con2 setup with my P1.7 for over 12 months now and they are still going strong. How have your relvol3's failed??
Any ground loops are the result of incorrect hook up between boards, not boards themselves. Wire all the boards with one connection to star ground, and only signal connections between boards and you won't have a problem with ground loops. My setup is completely silent.
If built and wired without errors (or faulty components) the dantimax stuff will work as advertised. I fried a controller chip early on by messing up the wiring, but once i had a replacement and corrected the hookup everything worked fine. I've also recently had a problem with a faulty encoder after 10 months of use, which Mikkel very kindly replaced even thought it is strictly an Alps manufacturing defect.
cheers
Paul
steenoe
quote:
F
Digikey has them (and will deal with privates) another option is Rifa PHE 426. Elfa has them in stock and they are the best price/performance choice (subjective oppinion ofcourse) They sound better than most other caps (another subjective, but there you go)
Page generated in 0.094872951507568 seconds with 17 queries,
spending 0.01738787 doing MySQL queries and 0.07748508 doing PHP things.
