diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Best 3" Voigt pipe plans? - Click HERE for Original Thread
Glowbug
Hey all...just picked up a set of Logitech "computer" speakers for next to nothing, and they have these neat 3" full range drivers with aluminum phase plugs. Not bad for $5 each. My plan is to junk the plastic cabinets and build a set of "real" enclosures for them, add BSC if necessary...basically see if I can get some decent sound out of these :D If I can't, oh well, I haven't lost much.
What would you guys recommend? I'm kinda looking at the Fostex FE87 recommend backhorn as a starting point, but English unit plans would help a lot :) What about Voigt pipes? I've got space for just about anything but open baffles :D
Thanks in advance.
Godzilla
http://www.cain-cain.com/noogi/index.html
can you say NOOGI?
Dumbass
You can't divide by two and a half?
Glowbug
http://xoomer.alice.it/0galavot/limes.html
That's exactly what I'm looking for, but there are no dimensions given, and the link doesn't work to the plans :(
gychang
quote:
can you say NOOGI?
I thought these speakers were big, is there a dimension measurement?
is there a way to find out if the tangband W3-871S would work?
thanks
gychang
Scottmoose
6x6x29in (external). It'd be easy enough to investigate an ML TQWT like these using similar dimensions for the aforementioned drivers.
loninappleton
quote:
Now I have another thread to subscribe to.
Here or elsewhere I fielded a question about the noogies and
and the tangbands. This seems to be a fit for the Voigt pipe
question but I have no idea on how to do the measures.
tubee
Search for: cyburg's needle
Like: http://www.plastichead.net/audiowor...les/w3s-871.htm
Made them but with 4 inch units.
loninappleton
What a guy (link to plastichead). He does glue-ups in his living room.
Ya gotta love it.
I tried some floor standing experiments with TB's using
PVC. After that I decided they belonged on the
desktop and so the Voigt/Noogi looks like a better
solution. It's better for the following reason: most
Voigts, while eclypsed by other designs for floor-standers,
are always described as 'forgiving' as far as a build goes.
At 30 inches or so and with the drive down a bit, it
puts the listening height pretty much in the zone for
desktop.
bcrescen
Not voight pipe but I used logitech 5300 speakers to make TB3 bipole by Salas. Really like them, small and easy to build. Search for TB3 in this forum.
Geoff H
Hi Glowbug. Have a look at my thread: www.diyaudio.com/forums/showthread....&threadid=89314
I don't know if they are the best, but they are much better than the original cases.
Have fun.
Jaime
If somebody want I have the Limes Plans and the Suono Magazine article.....
best regards Jaime
blumenco
if you could forward them to me some how, those plans would be an educating read.
the noogie is a is 1/3 scale abby, so think 2 feet tall. the driver is the ff85k, which to my knowledge is the greatest flux density to cone weight ratio driver fostex or anyone offers in the u.s. with a rising response in the upper range, it gives an effect of a super tweeter that makes 100hz. so above low bass, it can describe near infinite detail, it seems. I have had a blast playing with those drivers.
another thing to look at is the zigmahornet. plans on singledriver.com
planet10
quote:
Better plans here http://www.planet10-hifi.com/boxes-fostex.html
Zigmahornet is intended for 4"
dave
blumenco
I forget. I tend to think of what most people call a 3 inch, a 2 inch, and a 4 inch a 3 inch. 4.5 goes to 4, and 6.5 goes to 6. 8 is just 8.
I just measure the actual cone.
sorry to not use the same language here.
3 inch, or rather 2 inch drivers probably dissappear the most out of any driver. especially in the nearfield.
Clark
Jaime
You can download here the Limes article in the Souno magazine (Italy),
(2.2 MB). Very good. It will be available for 7 days
http://download.yousendit.com/CAE211391E2933A9
best regards Jaime
gychang
above plan is not there.
is there any suggestions of voight pipe for a 3"? I have build Cyburg Needles with these with BSC and they sound good.
I have extra and some plywood with itchy fingers. Any suggestion on the VP size etc.?
NOMINAL IMPEDANCE 8 Ω
SENSITIVITY 1W/1m 86 dB
FREQUENCY RESPONSE 110-20K Hz
FREE AIR RESONANCE 110 Hz
VOICE COIL DIAMETER 18.4 mm
Levc 0.097mH
Zo 56ohm
X-max 0.5 mm
Vas 1.65 Litr.
Qts 0.59
Qms 4.97
Qes 0.67
thanks,
gychang
Scottmoose
Voigt, please, Voigt. P.G.A.H. Voigt you know. ;)
An F-81 variation would be interesting...
GM
quote:
It's on the author's site now, though the drawing is a dead link. You can try emailing him, but with the last update being in 2002, one has to wonder if he's still around: http://xoomer.alice.it/0galavot/limes.html
GM
Page generated in 0.049041986465454 seconds with 17 queries,
spending 0.00964975 doing MySQL queries and 0.03939223 doing PHP things.
