diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
minimum gain for LM1875 - Click HERE for Original Thread
Leolabs
I'm planning to go for x10 rather than the usual x20 or more,just wondering what the minimum usable???x5???
CarlosT
Supposedly anything around 10 or lower, then you're risking oscillation...whatever that means :D
Leolabs
So what's your recommendation??Still stick to the usual x20??
Bob0513
The datasheet states the LM1875 is designed to be stable at gains of 10 or higher. Probably anything greater than around 12 will be fine in most designs. With gains less than about 12 you will have to design your board or p2p system well to prevent instability.
Page generated in 0.016412019729614 seconds with 16 queries,
spending 0.00691223 doing MySQL queries and 0.00949979 doing PHP things.
Please support our sponsor.
