diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
About 8 bits controler - Click HERE for Original Thread
TheNaive
Could any one recomend me the 8 bits controler. I want to made 256 steps volume. I heard that ADC0804 is not stable when use in 8 bits mode.
Thank you.
Nelson Pass
No it's fine, but if you put in free-running mode, then
you have to contend with the occasional LSB changing
value, not necessarily the DAC's fault. A little hysteresis
can fix that.
TheNaive
Thank you very much Mr. Pass.
Page generated in 0.018660068511963 seconds with 16 queries,
spending 0.00921011 doing MySQL queries and 0.00944996 doing PHP things.
