diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Zen ZV9 Question - Click HERE for Original Thread
Albertone
Hi!
I am building a Zen ZV9, so I am searching for a couple of 25k potentiometers. Nelson says in his pdf that all resistors are 1/4 W, so should I use a 1/4 watt potentiometer or can I use a pot with more power??
Nelson Pass
You can use any pot you like - it isn't going to conduct
signal, and of course you can substitute resistor values
until you get what you want, which is an output DC
voltage at 1/2 the regulated rail.
:cool:
Albertone
What an honor!! The Mighty Nelson Pass in person!!! :bigeyes: :bigeyes:
Forgive me for the idiot question, but I'm a newbie....
Thank you very much.. and thank you for this great amplifier!!!
Albertone
Sorry Nelson, but can I use this pot with the default resistor values?? (I absolutely don't want to make any error in the building!!)
Potentiometer
Alain Dupont
Albertone,
http://www.digikey.com
Ref# 490-2979-ND
Murata TRIMPOT CERM 25K OHM 12TRN TOP 250mW
http://rocky.digikey.com/WebLib/Mur...37%20series.pdf
As a good example...
Alain.
Albertone
So the one I selected won't work?? Because I'd like to mount a stereo one...
Alain Dupont
Albertone,
I can't reach the one you did choose, the link is not working
could you please give the reference ?
Alain.
Albertone
Of course! Here's the Digikey part number:
KKA2531S28-ND
Alain Dupont
Albertone,
Are we speaking of P1 the pot in the lower left of the schematic ex Fig #6
The point is each channel has to be adjusted separately
and the current in this pot is < 0.75 mA
so why not ; but quite overkill....
{plus to find the sweet pot of the second channel you'll have to add a separate
pot on one channel, not really easy}
And a 12, 15 or 20 turns will be much more easy to adjust !!!
Alain.
Albertone
Yes the P1... Isn't it the pot for adjusting the audio volume?
So... if i mount one per channel, I have to adjust the volume for each channel separately, right?? This doesn't look very nice....
Babowana
No.
P1 is to adjust the output DC voltage, which is to be 1/2 the regulated V.
As Papa already said . . . post#2 . . .
Albertone
Sorry.. I didn't read well... But how can I adjust the audio volume if P1 doesn't do this??
paulb
You need a preamplifier, or just a volume control potentiometer in front of the ZV9.
Albertone
Ok, now I understand how the circuit works!! Thank you!! :D
Babowana
quote:
:D
You must be a guy who always sleep in the classroom . . .
Don't make too much watermark on books :D
Page generated in 0.040595054626465 seconds with 17 queries,
spending 0.01337624 doing MySQL queries and 0.02721882 doing PHP things.
