diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
marantz cd4000 - Click HERE for Original Thread
homertooties
Hi everybody
Currently have a marantz cd4000 everthing works fine apart from
the display says no disc the disc does not spin just twitches a fraction stops and twitches again
Is this a simple vam1201 replacement or could it be board trouble instead .
The laser has been cleaned once with a dry brush disc and with alcohol on a cotton bud still same....
Appreciate any help as dont want to waste money on laser
jaycee
That does sound like a dead laser. If the laser cant see the disc, that's what happens as it runs through it's focus calibration stage. You should be able to see the laser lens move as it attempts to focus on the disc.
It might be worth trying to adjust the potentiometer on the laser itself - do this carefully though as over adjusting it can kill a working laser.
homertooties
Thankyou for a reply guess ill be putting in an order to cpc havent found them cheaper anywhere else....cheers
Page generated in 0.033963918685913 seconds with 16 queries,
spending 0.00721288 doing MySQL queries and 0.02675104 doing PHP things.
