diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Seems a good Diy idea !! - Click HERE for Original Thread
sivan_and
http://dogbreath.de/Resistors/Resistors.html
lineup
You can also
.... purchase resistive wire
with different thickness (current rating) and Ohm/meter coefficients.
You can buy these resistor wires rolled up on bobbins of a few sizes.
This way you will keep your power resistors intact.
Resistance wire material can be, for example:
Kanthal D --- Specific resistance: 1.3 Ω mm2 and 1 meter at +20 °C
Nikrothal 80 --- Specific resistance: 1.09 Ω mm2 and 1 meter at +20 °C
Resistance Wire, Info and buy:
http://www.elfa.se/elfa-bin/dyndok....dok=2012513.htm
Website:
http://www.elfa.se/en/
lineup
Page generated in 0.01754093170166 seconds with 17 queries,
spending 0.00706601 doing MySQL queries and 0.01047492 doing PHP things.
