diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
El Pipe-O is up at www.passdiy.com - Click HERE for Original Thread
Nelson Pass
Like the title sez:
Merry Xmas.
(later) Oh, uh, correct to www.passdiy.com
- Moderator Note: Fixed the title ;)
eLarson
It's... it's...
BEE-YOO-TI-FUL!!
Thanks, Nelson for a terrific Christmas present
and may God rest ye merry.
Erik
Dennis Hui
That's stunning looking... Probably the neatest use of
sonotubes since sonotube telescope tubes.
Thank you for another fun project.
Merry Christmas!
Dennis
eLarson
quote:
use of sonotubes since sonotube telescope tubes.
That's it! It reminded me of a Dobsonian reflector
telescope (the pre-party version with the box, that is.)
Always did want to build a 12" reflector... maybe
now it will be a 12" El Pipe-o. :)
Best,
Erik
stefanobilliani
Thanks! and Merry Xmas to all.
vpharris
N. P: That's just super! Thank you, and Merry Christmas.
grataku
Nelson, that was a very funny article. Sounds like the name alone brought back the good times in a grand scale. Must have been alot of fun to use an $20,000 amps to blow up $400 woofers. I wonder what it must have been like just before that happened. ;)
Thank You and Happy Holidays!
Duck-Twacy
I only see Dells
:confused:
Won
Did you try just typing it in? That seemed to work for me.
In the student center at the 'Tute, there used to be this ice cream store that had damn good icecream, and this big sonotube sub. Naturally, it was a Bose sonotube. What was interesting is that both "phases" of the woofer were loaded with transmission lines of different length. It's basically the transmission line equivalent to the acoustimass bass reflex alignment. Has anyone tried something like this?
-Won
Keld
Hi
Only see dells :
the link is dot com dot, so remove the last dot
Peter Daniel
quote:
Originally posted by Keld
Hi
Only see dells :
I fixed the problem.;)
Duck-Twacy
Much better :)
D*mn, that woofer (21") is discontinued :bawling:
Digi
I need a sub for my new project, El-Pipe-O may fit the bill. I wonder what Nelson's sub would look like if he built it like one of his own smoking appliances? J/K Time to track down some sonotubes and give it a whirl. Cool execution of a trannie line Nelson, thanks!!!
Rob
GRollins
If the original drivers Nelson used are no longer available, you could try for the Hartley 24" of legend. Last I heard, they were still available.
I believe Magnat also has a driver in that class.
If all else fails, you could try to score one of the old JBL or EV 30" drivers, though you'd have to locate somewhat larger tubing...
Grey
apassgear
Stunning project Nelson, thanks for this remarkable Christmas present.
My girlfriend agrees with Nelson. Size does matter!
Merry Xmas to everyone.
Nelson Pass
You know, I believe I must have subconciously remembered
the Dobsonians. Such elegant telescopes.
:santa2:
stefan
Santa Claus make gifts only for Christmas and Nelson Pass make this all the time!
jh6you
When I first saw El Pipe-O, I thought it as a gift box dropped into the fire place through the chimney.
Merry Christmas!
Duck-Twacy
I have a 8 foot ceiling.
What happens when you lay the tubes on the floor (against the walls)?
Maybe a bit offtopic here under amps :)
GRollins
Horizontal transmission lines work just fine. Better in fact, with the port being at the floor, you'll get a nice boundary to help things along. If they're at the junction between floor and wall, so much the better.
For that matter, the same principle works for reflex cabinets. It's not the laying down that makes the difference, it's the final position of the port.
Grey
planet10
Cool article Nelson... it will get a link from my TL site.
Just a note to those who want to build something like this.
With two drivers i would think that loading the drivers push-push would gain some advantages in terms of keeping the box from moving around (sonically & physically). A step further might be to take them a step further and make them (push-pull)-(push-push) as in these two examples which might be considered smaller pre-cursors.
Steve's Shiva Woofer and Chris Brady's which were inspired by Steve's (but finished 1st).
And despite its large size, El Pipe-O may well be far to small (actually far to small) to be optimal for the drivers used.
I wondered if the el pipe-o's line was actually big enuff. I don't currently have Martin King's software up & running (%$^& PCs), but i have gotten a preview copy of Rick Shultz's upcoming (audioXpress) alphaTL article. Rick has been using George Augspurger's software to explore quarter-wave space. The alphaTL is a TL with certain variables frozen so that a simple nomograph generated design can easily be produced. El Pipe-O falls into the definition of an alphaTL.
Early in his work, Martin found that TLs were often made with far to little cross-section to get the best performance out of them -- ironic that in a design intended to get magnificent bass, many TL are literally choking their potential. Running the numbers on the MCM drivers in the 144" long pipe, Rick's alphaTL indicates that an optimal pipe for a single one of these drivers is about 20" radius. For 2 drivers a 28" radius is suggested (and over 50 pounds of poly-fluff in each enclosure!).
I will try to get my "PC" up & running and see if i can run some more detailed sims using Martin's sw, but from Rick's work it is suggested that shortening the line and only running one driver per enclosure would actually be more effective.
It would be interesting to see how el pipe-O performed with a single driver in each.
(Note: i can't say much more about the alphaTL until such time as it is published in audioXpress -- but it (and future variations on the same theme from Rick) will make plug-n-play TL design a reality)
I currently have my 1st alphaTL running in my living room, and it is quite promising. The Mk IIs are on the drawing board, and a set of subs using 10" lambdas is in the pre-planning stage (i have to aquire drivers before they are no more).
dave
relder
Looks like these suckers can reproduce the brown noise:
quote:
You have to be careful about your tone arm, your windows, your neighbors, and your bowels.
Nelson Pass
quote:
We did that. (See the 2nd set of curves)
Nelson Pass
quote:
We were exploring that when we blew out the
drivers, so to speak.
planet10
quote:
I missed the whole part after the 1st XO... christmas dinner...
very cool. they look better as a single. Properly disguised it would be: "speaker, what speaker ... BTW what do those big columns do?"
dave
GRollins
If you planned ahead, you could build the TLs into the house, cleverly disguised as columns supporting the ceiling.
Shades of the houses they used to build with concrete horns under the floor...
Grey
Dennis Hui
dave
Yeah, if you finish them up nicely enough, those columns look
like funky modern art. :)
BTW, the post--party El Pilp-O's have drivers mounted facing
up. It seems then the driver cone will be resting a bit further
in the voice coil. Does this have any appreciable effect on
TS parameters, power handling and general longevity of
the driver? (I'd imagine the effect is minimal with a light
cone and a large magnet.)
Dennis
Nelson Pass
Finish? What's that?
Bricolo
maybe some painting
cyclotronguy
My instructions from Nelson are to either make it look perfect or like I just don't care.
Cyclotronguy
Dennis Hui
Actually I was thinking about how El-Pipe-O clones (or
smaller ones) can double as funky home decoration.
Hmmm...there are some 8" drivers in the basement.
Should see if any might be suitable for such a project.
Dennis
pinkmouse
Cool project Nelson, shame my room's far too small:bawling:
If you all out there can't find the 21" drivers Nelson uses, you might want to look at these Precision Devices drivers, they are widely used in the PA industry, and are absolutely stonking:D
lieven
it's that scandinavian guy with the typo who wasn't arround that day...
uvodee
quote:
ho is da na meugelek ?
http://www.t-linespeakers.org/projects/steve/index.html
Lieven, das zoe out as de stroat.
me vrendelijke groooten oit Federal Way.
J-P
Oz_Audio
I have been playing around with ideas for a new sub, I have been using a single Linkwitz Phoenix using 2 Peerless 12" XLS.
Having just seen this this morning, I shot down to the local concrete builder and aquired 2 12" storm water pipes (plastic), one is 1.5m long and the other is 2.5m long, unfortuanately not the some long length, but that was all be had and I got them for the correct price ($0), so I will have to play with what I've got.
After seeing the single driver. I fell in love, so the 2 tubes in the corners will do.
Now, if my thinking is right, there should be no 6dB baffle step problem, because the floor is infinately wide and if placed in a corner, some more dB in the lower range will also help?
Now out with the saw and router!
Mark
lieven
sorry jean-pierre,
dacht werkelijk origineel te zijn, mijn kennis vantengels is nie zo goe.
ps kennekiku?
transaltion:
Sorry, tried to invent warm water it seemed, but NP also did.
Something to add: See for Karlson-coupler: is also based on quarter-wave tube, but with exponential cut-out.
http://home.student.utwente.nl/e.j.j.ulfman/
mrfeedback
That's called El-Pooped-O. :D
miguel2
In the article the lengh of the pipe is well defined by the wavelenght but it seems that the diameter is only related to the driver's one. Always looked at the pipe organs and wondered how is the pipe diameter calculated. Hints? :confused:
lieven
could be related to air volume passing trough.
same with bass-reflex tubes: minimum diameter (breathing surface) required for not hearing whispering of air motion.
in other words: to avoid things like brown noises:)
uvodee
sorry jean-pierre, dacht werkelijk origineel te zijn, mijn kennis vantengels is nie zo goe. ps kennekiku?
nie erg, maar dat np een beetje oude koeien uit de gracht zou halen, dat had ik niet verwacht.
ik denk dat we mekaar nie kennen, woon al een jaarthe of 4 in de US
hebt gij eneige amps of pre amps van NP gemaakt?
ben mijne soz aan het ineenflansen.
MikeW
Can I get 800 watts out of a Zen to run EL-pipeO?
cyclotronguy
Stock up on the sun screen.
Cyclotronguy
Mark A. Gulbrandsen
My house has several extra unused chimneys at the moment....gives me some ideas here to ponder! Dang those would make solid tubes!
Mark
MikeW
Don't fall off the roof while you are mounting your speakers.
Dennis Hui
quote:
Mark
Hmmm...neat. A house with built-in subwoofers. :D
Dennis
lieven
quote:
Cyclotronguy
more noise to come?
MikeW
I came back from the Home Depot with the tubes for El-Pipe-O. I showed them to my sons. As I was leaving to put them in the work shop they said "I think dad has gone insane.". We'll see after I get that 4000 watt peak subwoofer amp going. Is that El-Pipe-O V.2 ?
uli
how do you call those amps?
"ALEPH 2000":D :D :D
Thinking of amps with their own builtin powerplant
Call it "Aleph Diesel"
Uli;)
xsnailx
should we invent an NUCLEAR ALEPH???;) ;) ;) ;)
Nelson Pass
Don't tempt Cyclotronguy like that.
:santa2:
G-Daddy
I was under the impression that a crucial feature of transmission line designs was the lack of parallel faces, in order to remove as many structure resonances as possible. All the MDF jigsaw-nightmare transmission-line designs I've seen have obviously taken care to flare the line in some way or another. So what about el-pipe-o? Is it a case of just living with the resonance as the price for such a convenient building material, or is there something more subtle going on here? If the batting packing can remove the resonances well enough, then why do the woodshop guys go through such pains to avoid parallel faces?
I'm lookiing at building a scaled down version of these monsters to back up some electrostatic panels, and I'd like to make the proper informed decisions now, before I start buying and constructing. Thanks for the info.
- Jonathan
planet10
quote:
That is really a side effect and not a purpose. It has been recently shown that a T-Line is just a name applied to a subset of quarter-wave speaker designs (includes Voigt pipes & horns). A TL is usually that subset that have no taper (straight pipe to designs that have a taper going from large (closed end) to small (open end). In a tapered line the geometry acts as a high pass filter for the terminus output, and moves the lines resonant frequency downward yielding a shorter (not necessarily smaller) line. Folding the taper into a rectangular box results in a box with 2 non-parallel sides and bracing running the long length of the cabinet at an angle -- both positive attributes that can be incorporated into any enclosure.
In el pipe-o the side-to-side standing wave of 2 feet is short enuff that it shouldn't be an issue given the frequencies it operates at or given the amount of stuffing in the line.
dave
Nelson Pass
To put a finer point on it, you will experience a resonance
at 1/2 wavelength for the diameter of the cylindrical pipe
which in this case is around 275 Hz. With a low pass filter
beginning at 22 Hz and stuffed with Dacron (tm), the
excitation at this frequency is slight.
xsnailx
Nelson,
I didnt want to tempt any one ;)
just tried to go further than aleph diesel:) and write something funny
but if i offended someone by writing this
i say sorry and i won't do it anymore
uli
quote:
Originally posted by xsnailx
Nelson,
Hi xsnailx,
Maybe NP fears a new design by cyclotronguy, which he has
to declare to some officials in the government and to customers
when he wants to sell that ALEPH 239 (Plutonium)
:clown: :clown: :clown:
Uli
cyclotronguy
I'm thinking a simple"flash reactor in the basement" Several thousand kilo-rad of neutron flux would be 'bout right for food storage. Could take the waste heat run an absorber..... drive a chiller into a thermal mass and cool the house in summer. Light from electrons jumping orbitals. endless possibilities.
Cyclotronguy:cool:
roddyama
Cyclotronguy:cool:
Mmuuuhaha, It Starts!:devilr:
Dennis Hui
How about the Aleph P-P (proton-proton)? I hear it
comes with a fusion generator. :)
Dennis
xsnailx
hmm seems like diesel is not enough
i live near russia so it will be cheap to get fuel for nuclear power plant
jag
Quote from el-pipe-o article
quote:
If you have an 8 foot ceiling, you can make two out of a 12 foot piece of 8 inch diameter, and find yourself decent 8 inch woofers resonant at about 40 Hz. Then you can start having parties, too.
Is this woofer okay for the application: PIONEER B20FU20-54F. The stereo pair will be driven by a 50-100w per channel stereo amp. Also, the low pass filter used with the original el-pipe-o is 12dB low-pass to provide a 13-75Hz response. Does this imply that I should use approx 40Hz 12dB low pass with the 8" woofer? Is such a low cutoof required to equilize the woofer response? Will a low Xmax woofer like the Pioneer mentioned above behave well in this kind of a situation? Any other suggestions for 8" driver appereciated...
Also, Nelson, pl, pl, please: give us the AXO :bawling:
planet10
quote:
Originally posted by jag
PIONEER B20FU20-54F
Qt is too low to work well in el pipe-o. look for a woofer with 0.5 ->1.0.
dave
uli
what about the lambda woofers?
Pretty high Qts and unbelievable p-p displacement.
Theyre on sale now as lambda quits business.
Uli ;)
jag
dave
This Stryke satisfies the Q requirement but effeciency is low (87) - The Pioneer above is 93...
Uli ;)
I do not see any 8 incher. Also, kind of expensive. I want to experiment with something inexpensive before I make an investment.
planet10
The Lambdas are good. I am trying to wangle a set of 4 of the 10" for a stereo pr of push-push woofers.
The inexpensive Lambda LE series will be unavailable after March 31, get 'em while you can. The good news is that Lambda is not going out of business. Nick has been able to put things together such that he can continue it as a part-time business.
dave
jag
No specs :mad:
planet10
No specs
You didn't dig deep enuff. ie TD10H. 10s are as small as they make thou.
dave
planet10
Not exactly subwoofer territory...
an el pipe-o for a single SA071 would be 51.5" long, 11.25" internal diameter, stuffed evenly with 0.96 pounds of fiberglass insulation OR 58" long, 10.3" internal diameter, stuffed with 0.76 pounds of polyester wool.
dave
jag
dave
Thanks! The Q is pretty low on these as well. They are sweet otherwise - looks like I will have to give up on el-pipe-o and go with a sealed box. I do not want the subwoofers to go too low - small room (standing waves), amplifier power, concern for neighbors, and integration with small bookshelfs (better go high than too low).
planet10
I'm gunning for this Lambda 10" from Stryke ... don't be afraid to email Nick & ask him if he has anything suitable (just be patient thou, he is overwhelmed at the moment)
dave
miguel2
I am planning to use this unknown driver I have to try this sub. It has 27 cm diameter on the rubber side of the driver and 31 cm on the outer side (iron structure). In the back it says AD 12200/W4 and two other big numbers :scratch:. For now I do not want to buy a new one.
My problem is to know what is the difference between the active and the passive crossovers that are presented in the article. I believe that in either way a sub amplifier must be used.
I intend to run the main speakers with a ZenV4 and use my rotel 921 to the sub.
Miguel
Nelson Pass
The passive version of the filter for driving a subwoofer off the main amp works very well. You will see that Vance Dickason did a similar one in his project for AudioXpress.
Nelson Pass
quote:
IMHO, one of the best aspects of a good, long, fat Transmission Line is that it is very forgiving of different driver characteristics. I just stuff it to taste to get more of what I want.
miguel2
Thanks for answering Mr. Pass. If I understand correctly (my english is giving up on me now), I just connect a 940 ohm resistor to each output on the Zen and then put the rest of the crossover (except the 470 ohm input resistor of the crossover). After this I put the Rotel and then the driver.
Is this correct?
Miguel
planet10
AD 12200/W4
That is a Philips driver. I just successfully put a pr of the 8 ohm version into a 2.5 cu ft aperiodic box.
dave
Nelson Pass
If you are making mono, then you want a 1000 ohm (close enuf)
resistor off each output and tied together instead of the original 470 ohm resistor.
miguel2
Yesterday I connected the driver to the output of the Zen without crossover and without the main speakers, just to see how it performs. Highs were inexistent and midrange was very shut in and muddy, but I think this is normal for a 30 cm driver. BUT the problem is that bass was absent too. My B&W 601 speakers go way more low, and they have the -3Hz point around 70 Hz.
I was not expecting to hear big bass, as it had no tube or box, but I was suprised not to hear any bass at all. Does this means that that driver is damaged? The middle part is wrinkled to the back but I think this has nothing to do with it.
IŽll try this weekend to build a crossover and see what hapens. For now I will build it with a 10 uF electrolytic before spending more money in a film one.
Miguel
planet10
[B]Yesterday I connected the driver to the output of the Zen without crossover
Not at all. Without a box the wave from the front gets cancelled by the anti-phase waves from the back for all frequencies below a 1/2 wavelength of the size of the driver. A trick to get some idea of how it will sound is to listen to the driver edge on.
dave
miguel2
quote:
...the driver edge on.
What do you mean by this?
do you know of any (internet) source where I can find the parameters for this specific driver?
Thanks.
Miguel
planet10
Hold the driver so that the edge of the basket is near your ear and the drivers centre axis is parallel to your head.
No
dave
miguel2
This weekend I finally built it. Got a 30 cm tube, cut it to 2.4 meters, so I have about 15 cm clearance to the ceiling and then put it over the driver. I was lucky because the tube fitted very well in the driver, with no other mounting material. I also used a rope to hold the thing standing up, as my 18 months kid found very funny to knock on it. BTW, as it is, waf factor is quite low :cannotbe:. Recommendations will be very welcome.
With the Rotel driving it, bass extension is quite nice. I had to be careful as windows were rattling every time I cranked the volume up. I used REM's "How west was won and where it got us" from New Adventures in HiFi to test it and was quite amazed. Now it seems that I have been missing a lot in the music I been hearing all this time.
Now I need to swap the 10 uF electrolytic I used in the xover to a film one (yes I made cheat at this). Maybe that is why I hear some voices in the subwoofer.
I also want to use the 2 channels of the Rotel to drive the sub. I am a bit afraid of connecting two inputs with the same signal and connect the outputs (+ with + and - with -). Any suggestions?
I didn't use any fibreglass inside the tube. Before buying some pillows to get some fibre, what modifications on sound should one expect?
planet10, before mounting this I used your advice to listen on the edge of the driver, and I could get an idea on its sound. It was nice as it gave me some confidence to built the whole thing after. Thanks.
Miguel
dieringe
I built small el-pipe-os with 15cm diameter and
tuned them to 30Hz or so (had some cheap drivers lying around)
The problem is, I run symmetric D1- and aleph-ono- output into the aleph 30 power amp (passive pre) and want to use an old Rotel for the pipeos.
How can I connect the active subwoofer filter described in the article? Do I need a transformer or is there a cheap trick that would do it?
Every time I tried connecting it so far I got big hum
I rather don't want to take the power amp output for a passive filter because they're too far away.
thanks -
martin
miguel2
Hi Martin,
Try to connect some wire between and earth point of the Rotel (chassis for instance) and an earth point in your Aleph 30 or preamp.
Miguel
Page generated in 0.16053605079651 seconds with 17 queries,
spending 0.00992179 doing MySQL queries and 0.15061426 doing PHP things.
