diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Opinion about this hi-fi amplifier - Click HERE for Original Thread
viktor1986
Hi
What's your opinion about this amplifier?;)
Gold_xyz
Hi viktor1986
at the first look it seems good ! :)
MikeB
I think, you should not use the "current mirror" formed by Q7/8. This way the outputvoltage to the 2nd stage is not clearly defined, giving unreliable bias in the 2nd stage.
It would work better with r21 replaced by a ccs, but the common mode voltage is still not defined, which can be anywhere between 0v and -Vcc. (Set by the ratio of currents delivered by Q7/8 and input-diffamp)
It's likely that the amp built that way will have no bias at all, or burn up r21.
For a better DC-balance you might move r1 to the other side of r2.
Okay, enough critics for one post... :clown:
Mike
EDIT: For a better understanding: This topology needs a voltage output from 1st stage rather than a current output.
jmateus
It really looks good! Is there any layout yet?
XEAGLEKEEPER
Looks real similar to ESP P101 lateral mosfet amp.
P.Lacombe
Hi MikeB,
Q7/Q8 don't form a current mirror, but a dual constant current sink. This can improve the linearity of the 1st stage, and increase dramatically the open loop gain...
... which can be the very best or the very worst thing, depending of the phase response of the whole amplifier. In other words, building of this amplifier is reserved to experienced persons...
Wavebourn
I like power filters with diodes.
MikeB
quote:
Originally posted by P.Lacombe
Hi MikeB,
Yes, that's true, that's why i wrote "Current mirror".
It does increase openloop gain, but the issue with voltage source vs current source keeps. The bias to 2nd stage is undefined. Try to calculate bias in 2nd stage... (without sims)
This would work perfect if 2nd stage would connect to 1st using folded cascode.
Mike
darkfenriz
I completely agree with Mike, this simply won't work.
R. Cordell used active loading of differential stage, but with bias feedback, so that voltage is defined. I also saw something like this in a class D amplifier (by classD4sure ?). Check them out.
http://www.diyaudio.com/forums/show...2746#post952746
http://www.cordellaudio.com/papers/...orrection.shtml
lineup
quote:
Originally posted by viktor1986
Hi
What is good with Lateral MOS, like 2SK1058 / 2SJ162,
is they are easy to parallel, compared to IRF HEXFET and Bipolar power transistors.
What I have read, you don't even have to use any emitter resistors
when parallel several www.renesas.com Laterals ( former Hitachi line ).
I don't think this is true for all lateral MOS.
There are several variants of laterals with different thermal behavior.
In your case you use 0.1 Ohm.
It wont hurt to use emittor resistors anyway
and also makes it much easier to set and measure the Idle Bias Current.
I think 2SK1058 has got considerably HIGHER RDS-on than most power HEXFET.
This also means that they will start clipping maybe already when
Volt Drain-Source is 4-6 volt.
So, when using Lateral MOS instead of vertical IRF HEXFET
you need maybe 3-6 volt higher voltage supply both in V+ V- half.
This makes a total of 6-12 VDC
and so transformer needs to be 4-8 VAC higher.
For example one amp IRF240 / IRF9240 uses 2x30 VAC. ( 60 VAC )
If using 2SK1058 / 2SJ162, maybe need 2X32-2x34 VAC. ( 64-68 VAC )
For same power output.
lineup
CBS240
Hi
I am currently sort of tinkering with a somewhat similar topology. I have to agree with Mike's comments though. If you replace Q7/Q8 with resistors, they would provide a reference for the second diff pair. If it were me, and my goal was to "linierize" the input diff, I would go for cascode and resistors instead of CCS's.... (J-fets MMMmmmm J-fets....and their high input impeadance :drool: ) Cascode is better and the resistors provide a reference for the second stage(Q11, Q12) then maybe R12 can be replace with a CCS for better common mode rejection in the second diff. If R10 in the swap mirror were replaced with a pot, the bias could be adjusted to the correct amount. I have a "homeade amp" that has been working and sounding great for quite some time, I usually just leave it on for days, no problems. It uses a swap mirror for the Q9/Q10 mirror place in this circuit. Speaking of mirrors, I've figured a way to implement a Thompson mirror in the case of the Q9/Q10 mirror for this type of topology that actually works.:cool: I love having to rebuild because of an upgrade....but that's DYI. :D
lineup
quote:
Originally posted by MikeB
I think, you should not use the "current mirror" formed by Q7/8. This way the outputv oltage to the 2nd stage is not clearly defined, giving unreliable bias in the 2nd stage.
I agree.
Unfortunately this setup wont work.
There is nothing that sets a stable current through
the important R22 pot in second stage.
Even if you replace Q7 / Q8 with resistors, the current in second stage
will depend on the current source into input differential pair.
And this current source is no good!
Will be like (Power supply Voltage)/(R9+R10).
And if power supply changes under working conditions
the current through R22 pot will change too.
I don't know why you don't use a precise LED CCS to supply Q1 + Q2 ????
Like the one used for Q7 + Q8.
A well defined stable current in second stage is VITAL,
if using only resistor for control of output stage bias!
But is also required very well defined and stable current in input pair
for best performance in all amps using dual transistor differential input.
If using a VBE multiplier instead of R22,
you might get away good with using only input stage CCS
to define Q1+Q2 current precisely and second stage current roughly.
Even if there are some other alternatives, I recommend the following:
1. Make a CCS for Q1+Q2 using a RED LED.
This LED should run at like 3-5 mA , set by a resistor from ground.
2. Replace Q7+Q8 with suitable resistors.
To set the current in Q9+Q11+Q10+Q12. See point #4.
3. Replace R22 Pot with a transistor VBE multiplier.
TO126 like MJE340, BD139 will do well.
Also TO92, like 2N5501, BC639, BC635, BC338, BC337 may be used, I think.
This transistor should not / does not have to be placed onto the main heatsink,
as far as I can understand.
4. I would say the current needed in Q10 -> VBE Multiplier -> Q12
to drive output transistors in a good way would be like:
10-15 mA per output pair, 2SK1058 / 2SJ162 ( 600pF / 900pF )
For two pairs like in your schematic, this means something like:
20-30 mA.
The same current will of course run in Q9+Q11.
Otherwise, you may keep your circuit basically the same
as what I can see at a very quick look.
It is a good circuit basically with a lot of potential for Hifi performance.
It shows that the designer has quite a bit of knowledge in Audio Amplifiers.
lineup
Lineup Audio Amplifiers
http://lineup.awardspace.com/
viktor1986
Here is new schematic...
burnedfingers
Sometime simple is better in both terms of sonic quality and performance. Why not consider the Nelson Pass A40 board with the output design of your choosing? This is a very good sounding amplifier that you can beat the snot out of and count on to run the next time you flip the switch.
I made some with bipolar output stage and I absolutely loved them. Sorry Nelson, I just understand bipolar better than mosfets.
With respect to the schematic you posted...well, it has too many faults. When you do modify it enough to work properly I believe it will have its own colored sonic signature. In the purest sense of audio shouldn't the program remain as close to natural as the original.
darkfenriz
Now it's OK, except the fact, that output stage bias is highly dependent on supply voltage.
Adam
viktor1986
Maybe this will help?
darkfenriz
Yes
lineup
New schematic attachment:
http://www.diyaudio.com/forums/atta...tamp=1163327250
I don't know why you use 2 resistors R9+R10 to set the current in input stage.
And this current mirrored by Q3-Q4-Q5-Q6.
Such a bias of the input pair Q1+Q2 s really bad, in a HIFI power amp.
And this in combination with only using a variable resistor R22
to set the idle current in output stage,
Sorry, to me it is almost foolish ......
For a mediocre amplifier maybe, but not for high class.
In a preamp we could use regulators, at lower powers and lower voltages.
But using regulators for a power amplifier, at least including the output stage,
is not what I consider a good option.
What is best and easy solution here?
- Using 2 resistors and an extra dual supply voltage regulator, at 50 Volt or more.
- Using a good normal: RED LED + 1 Transistor CCS
for Q1+Q2 and have a normal power supply.
Why complicate things?
Just to defend your idea from the beginning.
I just don't get it ....
Sorry, viktor.
lineup
ilimzn
A few points:
1) Lateral fets need about 12V Vgs to be at the edge of saturation at their maximum current, 7A. An amplifier with LFETs on the output should therefore have a separate power supply for the driving and input stages that is at least 12V higher than output stage power rail minimum (this is the dip of the ripple waveform at full load), plus whatever voltage drop is generated or required by the actual driver/input stages. This 12V saturation voltage is given as a maximum in the LMOS specs! An extra power supply will have other benefits, too.
2) There is nothing wrong with regulating LMOS idle current with resistor, assuming the differential driver stage current is well defined, and the resistor is VERY well bypassed (think what happens when current limit zeners do their work!). Of course, one could make a proper regulator here (TLxxx) but the problem is getting the temperature coefficient at worst zero. A regular Vbe multiplier will not work here (tempco, even off the ehatsink!), a bit more complexity is needed. The question is, is it required?
3) IS the driver stage current well defined? Well, in the first schematic it was completely undefined. In the second schematic it is dependant on the tail current of the input LTP. This in turn is defined by the positive power rail voltage for this stage. Assuming the power supply IS regulated, then there is nothing terribly wrong with the current mirror used to supply the tail current of the input LTP except that it is really needlessly complicated (and, IIRC, lifted right off a schematic by Dr. Bora Jagodic :) ). A standard cascode CCS would do better here, and, note to lineup, this is also dependant on the power rail voltage unless the current through the reference is also made constant (which brings us to 'recursion: see under 'recursion'' :) )
4) Easy paralleling of LMOS is a myth which will be corroborated by anyone who has ever serviced a Hafler amplifier with multiple LMOS pairs. They do share current far better than any other transistor without the addition of source resistors, but you really can't assume 2xLFET with Idmax=7A in parallel, means now Idmax is 14A. It is close, though!
CBS240
quote:
Originally posted by ilimzn
A few points:
An extra PS can be higher voltage, lower current, and have a steady voltage regulator. Have done similar(not with LFET though), but built 2 seperate "DC amplifiers", + & -, to power the driver section. This would make the DC steady, so the input stage bias mirror current would not fluctuate with ripple or rail noise so C3 is not needed. I used a cascaded J-fet CCS for this function instead of mirror.....IMO better.:)
viktor1986
Sorry, viktor.
lineup
Read this
http://www.jefspalace.be/analog/inp...nt%20source.php
wojtek5001
In Jef's current source current depends on Q3's Vbe (on first schematic). In Your CS current depends on supply voltage, because Q3-Q6 seems (at least for me ;) ) like a just slightly complicated current mirror.
Another thing: what is C7 purpose? I think it doesn't much in frequency compensation. Higher frequency voltage on Q11 collector is very small (due to C5). I saw this in many similar schematic and still don't understand, so if anyone can explain :confused: .... Maybe C5 is equal to input capacitance of output stage, then all becomes symmetrical and all right :rolleyes:
viktor1986
I think that now is OK.Do you think like me?:headbash: javascript:smilie(':headbash:')
lineup
viktor
this version is the best version so far, in my opinion
and this is the first version that could be called Hifi
A detail:
Because different exemplars of JFET can be very different,
you will have to adjust R7 (400 Ohm)
until you get the current you want to have
- in first input pair Q1,Q2
- which also will effect important current in Q10 - Q12, second stage
As I posted in another post,
I recommend Q10 and Q12 should have like 20-30 mA,
for driving 2 parallel pairs of mosfet of in good way.
This means you should have 40-60 mA through R21 (47 Ohm).
( My target value:
10-15mA per paralleled push-pull pair of output mosfet 2SK1058 / 2SJ162 )
If no other readers find some details that should be modified,
then you can start buying and building. :cool: :cool:
lineup
viktor1986
viktor
A detail:
( My target value:
lineup
I will match JFET-s with 2.5mA and 15-20V DC D-S
:D
lineup
Okay.
But you do not have to match them.
Not in this case.
Besides you will have to try VERY VERY many to find a close matched pair of JFET ....
Just pick two JFET exemplar, of that sort you want to use.
Those look like be 2N5484 and 2N5486.
But you can use many different JFET, for example 2SK170.
What type is not in any way critical as long as you make R6 big enough,
and so not leave more than 20-25 Volt across that 2N5484.
Or whatever max Vds JFET has.
(Frankly, I don't know what that upper 2N5486 is doing there: I would not need it!
Maybe someone will tell us what good (or bad :D ) this 2N5486 is doing ...)
Make a circuit with 40-50 VDC.
You can connect R6 (12 kOhm) temporary to 0 Volt, for this testing.
If you use your 2 x 50 VDC supply for this amplifier.
a) Then put them JFET into place. Together with R7 and R6.
b) Try with R7=390 Ohm
c) Measure current ( for exemple voltage across R6 /12000 )
d) If is too much current, increase resistance, try with R7=470 Ohm
....If is too little current, decrease resistance, try R7=330 Ohm
e) Measure and repeat until you get 2.5 mA,
or whatever current you want this CCS, current source, to give
lineup
ilimzn
OK, here's a slightly more detailed analysis...
1) R18, C5, C7
C7 would be Cdom only if C5 is removed completely and R18 adjusted for approximately equal voltage swing on collector of Q11 and Q12. Otherwise, C7 only sees milivolts of swing at HF so it's effectiveness is dubious. The problem is, you cannot adjust R18 to satisfy this.
Unlike the swing on C of Q12 (approximately = amplifier output), the swing on C of Q11 would be proportional to the actual current required to drive the output stage - essentially the error voltage between input and output of the output follower, that can have considerable distortion, especially with complex loads and MOSFETs: because they require current only to drive their nolinear Ciss, distorted to begin with, it gets worse with increased frequency because amplitude goes up. Potentially, it can get disastrous at clipping and especially at current limiting. This distorted waveform is additionally counterphase (although with differing amplitude) between Cs of Q11 and Q12, therefore nto common mode and it's effects are not cancelled by the LTP action. This all should be kept in mind because Vcb acts on a nonlinear Ccb in the BJT's of the driver stage, componding an already present distortion mechanism.
A way to largely reduce this problem can be seen in Quasi's design, as well as Symasym: what is Q11 in your design, is cascoded with another transistor with it's B on the output rail. This makes the voltage swing on Q11 and Q12 collectors approximately equal.
This has another desirable effect: A simulation will reveal that for most situations, the power dissipation of Q11 and Q12 will be nearly the same, so the offset introduced in the driver stage will be minimal. Similairly, the cascode transistor and what is Q10 in your design, will have similar power dissipation, but as long as Q9 and Q10 are thermally coupled, this will not influence offset. The low gm of the MOSFETs can. however, introduce an error, due to a part of the required sqing on C of Q12 that is proportional with output current (*), which can be signifficant due to low gm. A slight modification of the cascoding scheme is possible, which eqalizes the voltage swing on Q11 and Q12 collectors neraly perfectly, and also balances the current mirror, but I'm not going to reveal all my tricks :)
(*) There is a non-obvious danger of instability here, present also in single ended VAS designs. The voltage driving the output stage is a superposition of the required output voltage, and a voltage proportional to the output current, which will be out of phase for a reactive load - for low gm devices the latter can be quite high, especially for low load impedances. Being OUT OF PHASE, it makes the driver output also out of phase, and this is fed back through the miller comp ensation cap!
2) R19, R20
R19 and R20 are the same as input LTP, but this stage has an order of magnitude higher tail current. This is severe degeneration, more so given that the beta the BJTs in this stage is much lower than that of the input ones. You lose signifficant open loop gain. Still, degeneration is beneficial for linearity and stability, so keep it but use sensible values.
Here is a trick to make degeneration adjustable with a single resistor per stage, preserving symetrical clipping of the driver stage and DC conditions:
Make R21 into two resistors, 100 ohm each, one per emitter of Q11 and Q12. Then connect a resistor between the emitters, on the order of single digit ohms for this stage. No resistor, the amp is not differential. With a short, it is a non-degenerated LTP. Degeneration increases with the E-to-E resistor, n ohm or three will probably suffice. A similar thing for the input stage: split R6 into 2x 22 or 24k, once per E of input LTP BJTs, connect 18-22 ohms E-to-E. Varying this resistor changes degeneration without affecting DC conditions.
3) Driver/input stage power supply
Given a saturation voltage of 12V for the LMOS outputs, and drop on said resistors, let's investigate how we can optimize the driver and output power supply.
First, lets see if we can alow the input and driver stage to clip, without introducing unwanted charge storage effects. In this design, we can, because stage currents are strictly limited, by the input LTP tail CCS. In both stages current swing = tail current, there is nothing to oversaturate the BJTs. This is VERY important, it tells us what happens when the output stage clips for any reason. From this standpoint, this design is trouble-free, so we look at the output stage.
b)The overriding consideration here is LMOS Rdson and saturation. At Vgsmax (15V), this approaches 0.8 ohms - at Idmax, Vds will be 5.6V worst case. For this we need 15V Vgs, so it follows that the driver should be able to produce 9.4V more than the drain voltage, that being the output stage power rail. Driver rail should be a bit higher than output rail plus 9.4V, to account for the drop in the drived, about 2V here. How about clipping?
If the driver rail is equal to the output rail, then Vds will be higher than Idmax * Rdson. At Vd=Vg, 12V Vgs is required at 7A output current. The actual Vdg will be equal to driver voltage drop, so >0, However, this will only help a little - expect about 12-13V drop on the LMOS at maximum current - nearly 2.5 times that of the previous example. This means the dissipated power increases faster than load impedance decreases. Worse, current limiting the MOSFET may be no help - decreasing current increases voltage drop, but because saturation characteristic is nonlinear, curent limiting may even make things worse.
Regarding clipping, in the first case, the LMOS can always be driven to saturation, but for les than maximum current, ripple in the power rail will be routed to the output, during the clipped portion of the waveform. For the second case, this happens at maximum load and decreases with lower loads, the mechanism being feedthrough of the input stage clipping, since both see the same power supply ripple. It can be reduced by filtering - a moot point given the heat dissipation penalty.
A middle way is required. Obviousy a well filtered driver stage power supply (good short-term stiffness), preventing ripple feedthrough when driver is clipping, but this does not reduce the power dissipation penalty. We need a higher supply for the driver stage for that.
Can we get both, without another pair of power rails? There is, and it can be achieved in this design by rather curious means: the power supply rail has to be dimensioned to have about 11-12V ripple at maximum current.
Say what??? More ripple for better clipping? Here is how: The input stage, fed through a diode from the main rails, will catch the peak of the ripple in a local filter cap. At 12V ripple, it will be 11.4V OVER the lowest voltage of the power rail. 11.4V should cover the required 9.4V of Vg to Vd difference for good saturation, plus 2V lost in the driver stage. More than that and the bottom part of the power rail ripple gets through the saturated LMOS to the output in the clipped portions of the waveform. Any less, and the Vds and heat dissipation at clipping and Idmax rises. Less load means less ripple and less Vgs headroom, but also less load current, and with it, less required Vgs. With good filtering on the driver supply side provides minimum ripple feed through to the output when driver clips. It should also be noted that voltage drops in the driver or subsequent filtering of the driver rails should be taken into account and the power rail ripple RISED by that amount, if dissipation is to be minimized retaining gracefull clipping. Note that anything over 9.4V or so required for LMOS saturation increases the power dissipation penalty, and, also, do not take 9.4V as gospel - fine tweaking is necessary, as the 9.4V value is derived from worst case datasheet values.
So there, you learned a trick today :)
4) 0.1 ohm resistors in LMOS sources
Given the high Rdson, these will do nothing to balance load current sharing. They would at 0.5-1 ohms but this will further reduce the already low gm, and increase required drive voltage. Remove them, do some minimal work at LMOS pairing and properly estimate the protection fuse ratings. The low and flatter gm of the LMOS helps. Here is what to do:
Measure Vgs at known current Id (make it high, 1-2A) of your LFETs, at Vgd=0 (short G and D). Select pairs so that there is least difference Vgs a pair. Within a pair, there will be a higher Vgsh, and a lower, Vgsh.
Measure current through the LMOS with Vgsh, at Vgsl. It will be lower than the one used for the initial measurement, call it Idl. Chose the worst case Idl out of all pairs (both P and N).
Find maximum current at 50V (or your chosen output stage rail voltage) on the SOA graph, using the line of your choice (DC if you want to be dead sure, 100ms if you trust your fuses to blow quickly, or somewhere inbetween), call it Imax.
Calculate maximum fuse rating as Imax * (1 + Idl/Id).
You will find that using Imax * 1.5 is a safe bet with LMOS.
bogdan_borko
WOW!
RESPECT ILIMZN!
r!sc!
Hi ilimzn,
this is maybe offtopic, but i need to ask u what is your opinion about this two preamps? Here is DL link: http://rapidshare.com/files/3222318/Preamp_s.rar.html . The same topology, but with two different implementation.
Please, can u send me your e-mail to risci@softhome.net . Imam par pitanja vezano za gore pomenute preamp-ove ;). Hvala.
wojtek5001
1) Cascoding Q11 not solve my "unsymmetrical compensation problem" :) . When Q11 is cascoded in such way, then feedback through C7 will be in wrong phase, just like C1 connected to collector of Q12 and base Q11. So I still dont know purpose of C7.
2) I think that Q4 (the upper 2N5486) is for maintain constant drain-source voltage over Q3. In that conditions Q3 will be very good current source, immune to voltage swing.
ilimzn
quote:
Yes of course, you are right. It seems I accidentally deleted the sentence where i emphasized this, when editing to cut down size to 10000 characters (it was a bit over and would not post)
Of course, one could approximate an R18 to get some measure of compensation, but as I show in the above post, there are other considerations to this.
Exactly, this is a standard cascode FET CSS. The only thing is, residual capacitance may not be ideal because the Vds of the lower FET is quite low, but I think it will be just fine for this application.
I also forgot to mention that, to an extent, utilizing a high ripple PSU to get good clipping with minimum heat penalty, does increase distortion close to clipping, due to Cgd nonlinearity of the LFET. It is slightly better than VMOS/HEXFET and a lot better than ripple feedthrough, though.
CBS240
Hi
Just a little interesting info on j-fet CCS....
http://www.vishay.com/docs/70596/70596.pdf:)
Page generated in 0.12111902236938 seconds with 17 queries,
spending 0.00879741 doing MySQL queries and 0.11232162 doing PHP things.
Please support our sponsor.
