diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
anyone measure L(e) of FE166ES-R? - Click HERE for Original Thread
paba
Hi all,
datasheet doesn't show this value... and it is key to calculate Zobel network... I'm tempted to try a zobel to see what happens, my amp is tube output set to 8 ohms.
thanks
paba
ScottG
.83
paba
wow, that's the highest L(e) of all published Fostex specs...
so with R(e) = 6 ohms and L(e) = 0.83 mH then the Zobel would be R= 7.5 ohms and C = 14.76 uF or 15uf for standard value.
It will be some time before I get a chance to try and report back.
Thanks ScottG
cheers
paba
ScottG
Thanks ScottG
cheers
paba
Your welcome! ..but the thanks should be going to member Zaph (..he is the one that did the measuring).
Page generated in 0.021984100341797 seconds with 17 queries,
spending 0.00964880 doing MySQL queries and 0.01233530 doing PHP things.
