DIY A/V RCA Compression Connector Cables - Click HERE for Original Thread
morsel
You can make cheap audiophile quality cables comparable to expensive designer cables.
F/BNC/RCA compression connectors assemble quickly and easily with common varieties of coaxial cable and grip with 360° high strength retention, resulting in more reliable and robust connections than solder connectors.
