| bembel |
Hi all,
On the theme : "You'll never be bored with simulation", Here is another one:
SIMULATION LOG
Design: C:\Program Files\\BEMBEL simul\SCHEMAS\CurveTracer\tube curve tracer v2.1.DSN
Doc. no.: <NONE>
Revision: <NONE>
Author: <NONE>
Created: 07/11/06
Modified: 08/11/06
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [393D3051]...
PROSPICE Release 6.9 SP4 (C) Labcenter Electronics 1993-2006.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Reading SPICE models...
Loaded SPICE model '6CA7' from library 'VALVES'
Linked SPICE file '6AU6.inc'
Linked SPICE file '6al5.inc'
Linked SPICE file 'ECC82.inc'
Linked SPICE file 'ECF80_t.inc'
Linked SPICE file 'ECF80_p.inc'
Linked SPICE file 'EL84.inc'
Translated: GP A K VALUE={18E-4*(PWR(V(A,K)+0.2,1.5)+PWRS(V(A,K)+0.2,1.5))/2}
to BGP A K I= 18E-4*(PWR(V(A,K)+0.2,1.5)+PWRS(V(A,K)+0.2,1.5))/2
Building circuit...
Instantiating SPICE models...
FATAL: [SPICE] DCtrCurv: source vd not in circuit
Real Time Simulation failed to start
Totaliters=0, Totalsteps=0, Goodsteps=0, Badsteps=0
Real Time Simulation FAILED.
Any advice ??? (I didn't grab anything on google with this error message) |
| bembel |
I found this :
Fatal error: DCtrCurv: source <name> not in circuit
This error will appear when the voltage or current source
referenced in a .DC statement does not appear in the circuit
netlist. The string <name> will be replaced with the voltage
source reference designation that can not be found in the circuit
netlist.
But I have no V or I DCsources in the circuit (using alternators & diodes bridges) I don't have any "vd" object too.
??? Any help appreciated. |
| bembel |
problem solved
bad (not used) model in the same text file as a used one. |
