diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Worked first time-but not the second! - Click HERE for Original Thread
SuppersReady
Fired up first channel of my Aleph 5 last night. No problems, hooked up a signal generator, nicely undistorted tones. Let it warm through for an hour, and saw DC offset of approx. 0.7V (plus the sweet smell of cheap speaker coil). Switched off as it was getting late in the day.
This morning, Q6-Q8 are warming up fine, but Q18-Q20 are stone cold and no sound, aaarrrggghhh!!!
A few measurments:
Vgs: Q1=3.5V, Q2=0.666V, Q3=3.55V, Q6-Q8=4.24V (each), Q18-Q20=0V.
Vce: Q4=9.46V, Q5=4.54V.
No voltage drop across source resistors from negative rail to Q18-Q20.
0.6V drop across source resistors to Q6-Q8.
Voltage across Z5=8.98V.
Voltage across R11=0V. (?)
No smoke, crackles, glowing noted from any part of the circuit.
DC offset this morning = Supply voltage!
R11 and R14 both measure okay when power is off.
Am I right in saying that Q1-Q3 will all need replacing? Any ideas what might have caused them to blow? I would really appreciate any help/guidance that anyone can offer.
It's soooo much more annoying knowing it was working last night.
SuppersReady
Here's some pic's:
SuppersReady
A child friendly power supply:att'n:
SuppersReady
a family shot:
SuppersReady
A premature celebration
SuppersReady
Okay, so I just got back from work and tried it out again. Amp still doesn't warm up, but checked all the voltages again.
Q18-Q20=9.0V.
0.6V drop across source resistors from negative rail to Q18-Q20.
Voltage across R11=5.5V.
DC offset still Supply voltage.
Any advice?
Cheers
Paul
Zen Mod
pull out little bjt critters and measure them
in your nomenclature ( I presume its from origigi A5 serMan ?)
Q1 and Q2 must have same gs voltage ; Q2 seems stuffed
besides- DC offset is full MINUS supply ?
because 9 V of Ugs for Q18-20 are twice needed;
replace both Q1 and Q2 ,and use that Variac from picture to bring it slowly;also put some 1E/2W in-line with both rails as convenient fuses and measure points during tests.
and- 8E power resistor is ,on long way-cheaper than 5 cheap spks ;)
edit:
you have 9V across R14 just becuse Q1 must conduct current dedicated to Q2,besides his own current.
mebbe is JUST Q2 stuffed,but -in your boots- I would check pcb and solders for shorts and discontinuity..........all usuall mumbo jumbo
on the other side-with little trouble shooting adventure ,you'll certainly learn more about Alephs and electronics :clown:
EDIT II
seems that my fave board tech called Anatech is online-maybe he will giv'ya hand with your problem :devilr:
SuppersReady
Thanks Zen Mod,:)
As you say, I have been using the original service manual. Got some matched pair irf's on order from Tarasque so I'll make a start on the other channel in the meantime.
I have got some load resistors somewhere, but I haven't seen them since my last house move. Sounds like a good excuse to get some more.;)
The difference (just remeasured) is 1.5V less than the minus supply.
Again many thanks.
Paul
Page generated in 0.030600070953369 seconds with 17 queries,
spending 0.00969934 doing MySQL queries and 0.02090073 doing PHP things.
