diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
My 1st OB try.... Now that I know,, - Click HERE for Original Thread
JandG
I will be on to adding ribbons & active bottom end, actually active all the way around via Ashly xr4001, I am sure I need a parametric EQ now, so that is in line also. The Saba's have a nasty peak in them, but will take care of that. I wish I had a big room, but will have to do...off to play with some bottom support.The bass goes much lower than I would have thought, Not impact deep, but not expected.
PeteMcK
perhaps assymetry will get rid of the peak?
Have you played with 'The Edge"?...well worth the time
Pete McK
Page generated in 0.021209001541138 seconds with 17 queries,
spending 0.00804400 doing MySQL queries and 0.01316500 doing PHP things.
