| when the datasheet says "vertical mounting: up or down", does it mean... - Click HERE for Original Thread |
| jarthel |
I can mount a tube rectifier upside-down?
need to have it upside-down for a while so I can test a CCS circuit and the CCS circuit is mounted on the underside of the aluminum sheet.
I need to turn a trimmer so get the correct current output.
thanks for the reply. |
| Tweeker |
Yes, you can mount it upside down.
Dont mount mercury vapour rectifiers such as the 83 upside down though. |
