| Simple 12v mono power amp for bass driver - Click HERE for Original Thread |
| dhole |
Ello all
Im looking to build a mono power amp to power a subwoofer for my car .This being a diy forum there seems to be very little in the way of such things. Can anyone advise on an amp ? circuits etc ? Would have thought there would be.
cheers
dave |
| richie00boy |
| You need a switched mode power supply to get the necessary voltage rails, then any normal typical amp that can run 4 ohms will do. |
| dangus |
If you could score a broken car amp that still has a good power supply section, you could build your own power amp stage for it.
Or, you might come across an amp that just needs some basic repair like a busted volume control pot. (Like the 230 watt RMS mono Kenwood that I got at a flea market) |
| j.videtich |
There's one right here:
http://sound.westhost.com/project89.htm
That's a supply; then, just hook up whichever amp you want. It's a tricky supply, though; better would be a microcontroller-based PWM supply using an H-bridge FET configuration... if you can get the output filters right.
I built that project 89 supply, though I haven't put much of a load on it to test it out. It's a little uneven from rail to rail, which makes me worry I wound the tranny with an extra coil on one rail. It is doable, though. |
