| johnsciolino |
| Need this IC SUPERMATCH PAIR LM394 to get my ML No23 up and running. |
| jackinnj |
try Future Electronics -- this part was obsoleted by national semi a while ago -- you can also use the Analog Devices super-match pair.
jack |
| johnsciolino |
| I found datasheet on MAT02, says direct replacement for the LM394. |
| jackinnj |
MAT02 is obsolete --
Digikey has some SSM2210, and if you can take a minimum 50 pieces you can order directly from ADI. |
| jackinnj |
The SSM2210 and SSM2220 appear available on ADI's webstore -- in PDIP and SOIC.
Bob Pease has a good article in his archive on super-matching transistors. |
| Apex Jr |
I have 4 pieces of National LM 394 H in stock
PM me if your interested, not sure what the difference is
between the LM 394BH and the LM 394H
Steve @ Apex Jr. |
