diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Needed: 250 ohm : 50K Input Transformer HELP! - Click HERE for Original Thread
fastheadache
I've been searching for this part for some time with no luck.
I need a Microtran mic input transformer, 250 ohm : 50K, single threaded stud mounting type (5/16" iirc).
I'll consider other makes as long as the specs and connector are identical. I could probably use several of these!
Also, if anyone has any advice on where to look, please advise.
Thanks!!!
Jason
Lord Winter
Amplimo TM3
fastheadache
Thanks very much!
It appears this is the just about the closest spec I'm going to get.
(Beyer Dynamic p/n TR/BV 351.015.006 is similar).
If nothing else turns up in the next few days I'll try the Amplimo part. Thanks again!
Page generated in 0.017085075378418 seconds with 17 queries,
spending 0.00682569 doing MySQL queries and 0.01025939 doing PHP things.
Please support our sponsor.
