diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Looking For Black Glossy Formica - Click HERE for Original Thread
hongrn
I'm looking for a vendor who sells black glossy thin formica or wilsonart to cover speaker boxes. Most of the stuff I found is too thick, too hard and mostly designed for countertops. Thank you in advance.
Hong
pinkmouse
Dig out your yellow pages and look for your nearest shop fitting company. They will have all the catalogues for laminate, and will either give you details of your local distributors or possibly order it in for you if you ask nicely.
Aengus
The laminate you are looking for is called something like post-bending; it is designed to be installed on curves without heat. I have some covering into a 12" diameter (say, 30cm.) column and it would have bent to a much smaller radius.
Aengus
Page generated in 0.018654108047485 seconds with 16 queries,
spending 0.00903082 doing MySQL queries and 0.00962329 doing PHP things.
